SolaraGuy.com • View topic - "normal" rmp range
"normal" rmp range
"normal" rmp range
Postby Missay » Fri Mar 21, 2003 11:12 pm
i'm just curious what most solaras rev at when you first start the car?
when i start the car it revs at like 2-2.5rmps. isn't that a little high? my father..aka. "mr. know it all" is too funny. he walked me out to my car the other day and was all shocked when he heard it running like "omg..since when has your car sounded that loud! why didn't you mention anythign to me!"
HELLO! how long have i been saying that it sounds horrible! lol
*when the car idles after starting it's like 2.2rmps.
*if i put my foot on the brake and put it into gear it drastically drops to like .9 or 1.2rmps.
*if i put it back in park it shoot up to the 2rmp range.
*when i punched the gas in park (rmps went to like 6 or 7) then took my foot off the brake, the rmps went a little lower, but still stayed at like 1.5.
*at red lights the rmps are basically normal at .9-1.4ish give or take.
Melissa
Missay
SolaraGuy Ambassador
Postby pecora55 » Fri Mar 21, 2003 11:16 pm
when mine is sitting after i turned it on and it is idling its at about 800 rpms
Goodbye solara, loved you while i had you :( now into my bros hands, and hello Spec V...BYE BYE SpecV HELLO 04 Maxima ;)
'04 Maxima SE
'03 Sentra SpecV(SOLD)
'99 Solara SLE V6 Auto(SOLD)
pecora55
Postby Missay » Fri Mar 21, 2003 11:17 pm
maybe this would explain the 8-13mpg i've been getting :o
(ooo..i got 130miles out of my last tank! :roll: )
Melissa
Missay
Postby ChiTownSolara » Sat Mar 22, 2003 1:11 am
only 130 miles out of a full tank of gas?!?! SICK! i get like 300 miiles from my tank when its full and that is with some "enthusiastic" driving to!
ChiTownSolara
Postby 20SoLaRa02 » Sat Mar 22, 2003 1:16 am
yea ur idle is probably holding a bit high.....but if ur car is cold when u check ur rpm's its gonna be high. after you drive ur car around and know its fully warmed up through it in park and see what the rpms are at. Also if u put it in drive and ur rps are normal then i don't think that is ur problem of poor gas mileage.....i still think its something else and u really need to get taht fixed because u've had that problem for a while!!
good luck
-michael
20SoLaRa02
Postby Hsakuragi » Sat Mar 22, 2003 2:58 am
I think the "normal" idle when u strat your car in when the engine is cold is around 1600- 1900, it should not go higher than that. There is a way on adjusting the idle but not sure exactly how though...
Hsakuragi
Postby DavPak » Sat Mar 22, 2003 5:19 am
Missay wrote:maybe this would explain the 8-13mpg i've been getting :o
man i was pissed yesterday when i only got 383 miles on the tank! i cursed the oxygenated winter gas we're still getting!
missay, your idle sounds high, maybe you're having temp sensor issues. the car should idle high in colder weather so that the car warms up quicker, all toyotas (well, newer ones at least) do this. same thing with overdrive, it won't shift into overdrive unless the car is warm enough. in this way, the car warms itself up quicker. but once its warm, the idle should be back to normal.
'02 Solara S/C'ed V6 5-spd
DavPak
Postby Yanks0114 » Sat Mar 22, 2003 8:23 am
Missay,
Your idle is definately too high. Even on the coldest days my car idles at 1800rpm, and when i put it into reverse or drive it goes down to like 1000. Once it gets warmed up it should idle at 600 or so. As for the gas mileage, that is very low but it takes you 3 weeks to go through a tank still right? The winter has killed my gas mileage, its down at like 17mpg and i go through a tank a week.
Postby happy_aggies » Sat Mar 22, 2003 8:43 am
My idle is like Yanks0114,
around 1600-1800 when cold, and progressively goes down.
Usually around 300-320 miles for full tank.
happy_aggies
Postby Jackass-Jeff » Sat Mar 22, 2003 9:36 am
normal idle on autos is 750 (from what I remember from automotive class :D )
I think there is an idle adjustment screw in the engine bay... where on the solara, i have no idea (unless it's electronic now) and you can adjust the idle rpm (recommended to be done when it's warmed up at operating temp) but that milage... 0_0
1GR-FE ftw!
Jackass-Jeff
Postby cdssolara » Sat Mar 22, 2003 10:21 am
Mine idles around 1600-1700 when it's cold, but after it's warmed up it idles just below 700 rpm.
130 miles from a full tank? Something is definitely wrong. Assuming you're using around 16 gallons, that's just over 8 miles per gallon. At today's gas prices, that's got to hurt.
cdssolara
Re: "normal" rmp range
Postby NASTY » Sat Mar 22, 2003 12:41 pm
Missay wrote:*when i punched the gas in park (rmps went to like 6 or 7)
:o ouch! dont do that, youre going to kill her!
anyways, on a really cold day the RPM's will hit 2000, but I've never seen it go over (even in REALLY cold weather)
If it actually idles at 2500 somethings definitely wrong!
Next time you go somewhere, check what your car is idling at just before you turn off the car (while in park), after the engine is nice and warm. It should be between 6 and 7 hundred.
'01 SLE V6
NASTY
Postby swimshady906 » Sun Mar 23, 2003 9:09 am
How cold is it outside when you tested it Missay? I know when its cold here < 50 F hehe> when i start it up the RPMS avg about 2200 for only mebbe 30 seconds then they drop to like 1800 and then to an eventuall 800 when the car is warmed up... seems pretty normal. as for the idle screw... i would imagine its electronic now????
02' S2000 Silverstone
swimshady906
Postby Yanks0114 » Sun Mar 23, 2003 9:10 am
swimshady906 wrote:How cold is it outside when you tested it Missay? I know when its cold here < 50 F hehe> when i start it up the RPMS avg about 2200 for only mebbe 30 seconds then they drop to like 1800 and then to an eventuall 800 when the car is warmed up... seems pretty normal. as for the idle screw... i would imagine its electronic now????
The idle screw is still manual as far as i know. You have to sometimes adjust it when installing the supercharger. Your idle is pretty high too. By cold we are talking about anywhere from 0-20 degrees F
Postby Jai_Jai_Binks » Tue Mar 25, 2003 10:59 am
I've had my Camry Idle that high too..its just the cold weather...When the engine is cold or been sitting for a while. regarding milage, i think 130 is BAD! Worst i've had was 180 with FULL CITY stop&Go driving! What RPM's are you at Missay when your engine is warmed up?
