SolaraGuy.com • View topic - dome light
dome light
dome light
Postby bzyrice » Mon Jan 22, 2007 7:00 pm
The dome light works when i turn the switch.. but it doesnt work when i open the door.. any ideas? i checked the fuse in the engine bay.. and changed it just in case.. but that didnt work.. anyone?
btw.. the light on the cluster works when i open the door also.. so dont know what it is..
where is the fuse panel in the car?
bzyrice
Postby woa_its_j3ff » Mon Jan 22, 2007 7:10 pm
did you try a new bulb?
Postby anttarz » Mon Jan 22, 2007 7:25 pm
new bulb
anttarz
Postby Jon11582 » Mon Jan 22, 2007 7:27 pm
Ok I hate to say this but you didnt explicitly say that it is...
So without further ado...is the dome light switch set to "door"?
2000 Black Solara SE
Jon11582
Postby woa_its_j3ff » Mon Jan 22, 2007 8:12 pm
Jon11582 wrote:Ok I hate to say this but you didnt explicitly say that it is...
:lol: i thought that too but id think he'd know what position the switch is in..
I hope. :drinking:
Postby krook » Mon Jan 22, 2007 8:27 pm
are both doors like that or is it just the driver's door that doesn't turn the dome light on?
if the passenger door turns on the dome light when opened, then you probably have a bad pinswitch on your driver's door side. WD-40 it a little (the pinswitch) and push it in and release a couple of times.
the pinswitch is on the body of the car
krook
Postby Toy1mzfe » Mon Jan 22, 2007 8:38 pm
see if the button on the door is working right (in the door jam). You should be able to push it in and it shoudl push out. see if thats broken or not.
Postby Jai_Jai_Binks » Tue Jan 23, 2007 11:12 am
Toy1mzfe wrote:see if the button on the door is working right (in the door jam). You should be able to push it in and it shoudl push out. see if thats broken or not.
What others stated here. But just to add to them:
Remove the black rubber thingie. Spray wd40 or lubrication of any sort. And then push in and out to lube it. This method worked on my ES doors.
Postby bzyrice » Wed Mar 07, 2007 9:05 pm
whoops.. forgot i posted this.. just to let u guys know.. light bulb was ok.. it didnt work for both doors.. but the door open light on the dash board came on? that is why i did not think it was the pin switches..
anywho. doesnt matter anymore since car is sold..
bzyrice
Postby bzyrice » Wed Mar 07, 2007 9:06 pm
btw yes i did check the switch.. about 500 times.. cuz it was soo freakin annoying lol..
bzyrice
Postby mettler » Thu Mar 08, 2007 7:33 am
this is the exact problem I am having. I can't figure it out. Unless there is some weird double-tap thing you can do with the remote key, because that is when it all happened - when I was unlocking the door - I have no idea what is going on.
It must be the light buld - which looks fine, but I took a voltage reading across the terminals with the lightbulb out and the door open and got the 12v. So, I know it is getting power.
http://www.facebook.com/pages/Ice-Dragon-Cooling/139536759426738
mettler
