SolaraGuy.com • View topic - window issue
window issue
window issue
Postby woa_its_j3ff » Wed Feb 07, 2007 7:50 pm
Okay a while back my driver side window fell down when i was rolling it down (in the summer), and i took apart my door panel and realized the belt that runs on the pulley with the motor to make the window go up and down, had ridden OFF the pulley. so when i push the button u hear the motor working but the window wont move (obviously) so now i have the window ghetto rigged (you cant see it since it's in between the door panel) to stay up.
I have tried to putting the belt back onto the pulley or w/e but attempts have failed. So...
Do any of you guys know about how much it is to get this thing fixed?
Id ask you guys before taking it to the stealership or anywhere else.
sidenote -- > my passenger window's motor seems to be going out too.
Postby Ruski » Wed Feb 07, 2007 8:05 pm
just get new motors there like 100 $ if im correct, i had my dads window motor replaced for 25$$ labor
Postby woa_its_j3ff » Wed Feb 07, 2007 8:10 pm
Ruskimafia wrote:just get new motors there like 100 $ if im correct, i had my dads window motor replaced for 25$$ labor
new motors for both?
but what about my driver side issue? I dont want to pay toyota like 300 bucks just to fix the window.
Postby krook » Thu Feb 08, 2007 4:24 am
just take apart your window and have a look for yourself. it's pretty straightforward...but it's a bitch to put back. you'll need an extra pair of hands.
i replaced my driver's side window motor in just under an hour with some help. worse comes to worse, just buy the part from the dealer and DIY.
krook
Postby hskrsolara » Thu Feb 08, 2007 11:45 pm
I would suggest a DIY...once you remove the door panel, you will see that it really is not that tough to replace.
Check ebay, they have regulators and motors for sale all the time. Just replace both regulators at once and be done with it. Good luck.
hskrsolara
Postby woa_its_j3ff » Fri Feb 09, 2007 12:02 am
hskrsolara wrote:I would suggest a DIY...once you remove the door panel, you will see that it really is not that tough to replace.
what is the regulator, what does it include?
cuz i thought my issue is jsut simply putting the belt thing back onto the pulley (another thing I'm not sure how to do)
Postby lilm » Fri Feb 09, 2007 9:55 am
i made a small tutorial a couple days ago about the window regualtor/motor...........
are you saying thatthe metal string fell off the plastic pullys?
If so then just unbolt the pully place the string back and bolt it back up
the regualtor is the wire, the long metal guide and the blastic thing that the motor is screwd into....you should have to replace the regulator inless sometihng is really broken i.e. the plastic is cracked or the wire snaped
lilm
Postby woa_its_j3ff » Fri Feb 09, 2007 10:05 am
lilm111 wrote:i made a small tutorial a couple days ago about the window regualtor/motor...........
oh thanks man. everything works fine nothing is broken as far as i know when i took the door apart. just the wire fell off the pulley. i tried putting it back on but it's damn hard, couldnt move that pulley for some reason...
so im guessing i dont need to replace anything (just judging by from what i read)
Postby lilm » Sat Feb 10, 2007 3:31 pm
if the wires wont move what i wuold do is take off the middl pully the one with the motor and see if you can move it in there....thats where mine was stuck
lilm
