SolaraGuy.com • View topic - Brakes
Brakes
Brakes
Postby sel2000 » Wed Feb 14, 2007 8:26 am
I replaced the front calipers, rotors and brake pads on my 2000 SEL Solara in April 2006 at a local shop in Richmond Hill. Brake warning light comes on in February 2007 and dealer discovers calipers leaking and brake pads soaked in fluid!! S0 $900 to the first shop for brakes all around and 10 months later $600 for the dealer to rebuild the front. To say the least I am not impressed.
sel2000
Postby Eye8Pussies » Wed Feb 14, 2007 11:47 am
if you got new front calipers and all brake components done at one shop less than a year before failure, you should return to the original shop.
brakes
Postby Sentinel » Wed Feb 14, 2007 12:50 pm
You definately need to see if theres a warranty on those calipers (you'll usually get a year on parts)
Why'd you replace the calipers to begin with?
Sentinel
Re: brakes
Postby **PoshPepper** » Wed Feb 14, 2007 12:55 pm
That was going to be my question also...
The Original... SOcalLARA
Milt's OTHER ride
**PoshPepper**
Postby indiglosolara » Wed Feb 14, 2007 1:05 pm
The shop probably didn't use OEM calipars and rebuilds of some aftermarket ones...
This is why i stick to OEM on some stuff...
indiglosolara
Solara 2 xB
Solara 2 xB
Postby sel2000 » Thu Feb 15, 2007 8:15 am
Calipers were replaced as they were sticking, seized on one side and causing brake chatter in the front end. Probably a result of road salt corrosion. Thanks for the comments, dealer is expensive, but at least the quality is there.
sel2000
Postby Candyman » Sat Feb 17, 2007 9:02 pm
Was this in Richmond Hill Ontario? If yes please let me know what shop so I do not go there.
CM
Candyman
