SolaraGuy.com • View topic - Bad front struts??
Bad front struts??
Bad front struts??
Postby babidol4150 » Wed Feb 21, 2007 5:57 pm
Hey, I was wondering if any of you have had problems with your front struts? My car is a 99 and only has 62,000 miles on it and I think the struts are already going on the car. There is a lot of clanging and banging in the front, especially when I go over speed bumps. I read somewhere that there was a recall on this but I can't seem to find where I read that. i think it's crappy that i am going to have to replace them already. :roll:
babidol4150
Postby Ruski » Wed Feb 21, 2007 7:27 pm
Probably lose top mount I had that in my rear but jsut decided to replace all off them
Postby jhenty » Wed Feb 21, 2007 7:30 pm
strut mount or sway bar links? Check the sway bar links first before you jump to struts, then check out if the towers are making the noise.
2005 Subaru legacy GT
1990 BMW 535i
jhenty
Postby deus85 » Wed Feb 21, 2007 7:56 pm
Seems like everyone had problems with their struts. I just replaced the link on the front left and it helped with the majority of the noise. I am planning on replacing the sway bar bushing next. I've already replaced the rubber parts in the strut assembly and that didn't help. Now I still have some rattling when I go over bumps or driving on/off my driveway.
So definitely, check the links first.
deus85
Postby Ruski » Wed Feb 21, 2007 8:09 pm
i have been having really loud thump noise when i turn the wheel or start moving sound like a sway bar link retracting or engaging had this problem at first when installed struts replaced that strut b/c it blow and got new link noise stopped for a week then came back any ideas guys Sorry for taking your thread topic for this Q it just sound related
Postby babidol4150 » Thu Feb 22, 2007 7:03 am
not a problem, I heard this was a pretty common problem with the solara's, I just wanted to be sure. I will have to get my husband out there to check for me.
babidol4150
Postby Jai_Jai_Binks » Thu Feb 22, 2007 10:07 am
Thats the first i've heard that us gen1/1.5 solara have a consistant front suspension problem. I'm guessing its islolated incidents. The first sign of worn out struts is your car bottoming out and you hearing a lot thump!
Postby unbalancedwood » Thu Feb 22, 2007 5:36 pm
I may have some OEM struts and springs for sale soon :)
unbalancedwood
Bad front struts??
Postby Jeffrey Olson » Sat Feb 24, 2007 11:46 am
Consumers Reports says that the 99 and 03 suspensions are "good" and 04 Solaras suspension is "poor" . Good is in the middle and poor is the worst.
I replaced the front shocks and mounts and all the rattles went away. The rears are next...
Jeffrey Olson
Postby ZXLNT » Fri Mar 02, 2007 5:25 am
The early Solaras have a fairly well known problem with the rubber spring mount wearing. They get loose or worn and rattle like crazy. Toyota may cover or at least partially cover it, even out of warranty..
ZXLNT
