SolaraGuy.com • View topic - Gas mileage going down
Postby Jeffrey Olson » Wed Mar 07, 2007 9:30 am
When I got my 99 SE with 92K miles in July it got 31 to 33 mpg. Now, with 107K miles it is getting 25 to 26 mpg. I replaced really aggressive tires with some Michelins, the front and rear left wheel bearings, the front struts, the air cleaner, and that's it. The previous owner assured me all regular maintanence had been done - including timing belt. The car has lots of power - that hasn't changed, just the gas mileage
Any suggestions as to cause, or what you would do to elminate obvious potential reasons?
Thanks...
Jeff Olson
Martin, SD
Jeffrey Olson
Postby MCOjerry » Wed Mar 07, 2007 9:36 am
Could be the winter weather. You haven't owned it through a winter yet.
Postby unbalancedwood » Wed Mar 07, 2007 9:40 am
^ Winter weather could be. I have noticed a decrease in gas, but i can never be sure what the problem may be cause I do a lot of short trips, 5-10mins being in college gotta make runs to walmart and such. I really dont, cant notice if Im having a problem with gas untill I make trips home where I drive 260miles each way, but...
I have about the same mileage on my ticker, I have, or planning on replacing the following:
Fuel filter
Mobil 1 synthetic
Transmission fluid (drain and fill 3-4 times)
Top Valve Cover Gasket (small oil leak)
Coolant flush w/ Orange Prestone or Red Toyota
Seafoam before the next oil change...
All i can think of right now...
Last edited by unbalancedwood on Wed Mar 07, 2007 9:43 am, edited 1 time in total.
unbalancedwood
Postby ClassySolaraGuy » Wed Mar 07, 2007 9:40 am
Here are a few to consider:
-Oxygen sensors
-Fuel Filter
-Clean injectors
-Spark plugs, wires
-Tire pressure
-Heavy foot..lol :lol:
What weight oil are you using?
ClassySolaraGuy
1 Rockin' Solara
1 Rockin' Solara
Postby woa_its_j3ff » Wed Mar 07, 2007 11:09 am
my car seems to get like 19 mpg city and 21 mpg highway..
it eats gas. and i dont have a heavy foot. maybe it's the mileage. 123k
or im leaning more towards the winter weather :(
Postby Grnarowana » Wed Mar 07, 2007 11:16 am
i'm almost 112K and driving from norcal to socal, i still get at least 450miles until empty. and i'm running a 99' V6 SE stick
All i did was regular maintenence and spark plugs not goin to be changed until 120K.
Grnarowana
Postby onefiend » Wed Mar 07, 2007 11:24 am
woa_its_j3ff wrote:my car seems to get like 19 mpg city and 21 mpg highway..
you're gettin some crappy gas mileage, you might want to get a tune-up.
2007 Camry SE V6
onefiend
Postby woa_its_j3ff » Wed Mar 07, 2007 11:26 am
going to the stealership this weekend. looks like it needs some major maintenance.
Postby mettler » Wed Mar 07, 2007 11:40 am
I've got 119k on my 2000 and still get 30mpg on the hwy.
http://www.facebook.com/pages/Ice-Dragon-Cooling/139536759426738
mettler
Postby gone » Wed Mar 07, 2007 12:25 pm
i got a gen.2 and getting horribleeee mpg. ive been getting 18.4 mpg average everyday so far. it sux. i was wondering wats going on with my ride also
gone
Postby Paladin06Greg » Wed Mar 07, 2007 12:31 pm
19 miles to the gallon. You should be happy. I can not get 19 miles to the gallon if I drive down hill all the time. :)
Paladin06Greg
Torqued Solara
Torqued Solara
Postby Jeffrey Olson » Wed Mar 07, 2007 3:55 pm
My 99 SE has a six with an auto. The mileage did start to go down when it started getting cold. I drive 500 miles or more a week and use the cruise control 98% of the time I'm driving. It seems to burn about a quart of oil every 3000 miles, but after owning a VW bus, that seems like nothing.
I'm bothered by 26 mpg. If I were getting any less I'd be in a major depression - I bought this car for the power/gas mileage relationship. I think it's time for the stealership (I like that nickname). Black Hills Toyota lets me watch the mechanic while he works, so I'll see what he does.
Someone said they got a scangauge II. I got one. What should the readings be for the solara on the following systems?
Fuel Economy
» Intake Air Temperature
» manifold Pressure
» Engine Load
» Throttle Position
» Ignition Timing
» Open/Closed Loop
Jeff Olson
Martin, SD
Jeffrey Olson
Postby Sap Z » Thu Mar 08, 2007 1:29 pm
wait wait..29-30 on a solara?
I've never passed 23.5 on my solara! even in the summers. I'm at 116K, heres what i had done
New tires..air checked.
Spark plugs
Water Pump and belts changed.
Fuel injector cleaner (use once in 6 months)
Regular oil change
K&N air filter
and i'm fed up of the mpg's i'm getting - i only use BP 87 grade gas. (i've tried premium n had no change). I drive city/hwy mix
any suggestions?
SapZ
V6 SE DWP
Sap Z
Postby kingkakyle » Thu Mar 08, 2007 1:41 pm
u have a v6?
and u got 30 highway?
i think the most ive gotten highway was 34 and that was straight flat highway
mixed i get like 25ish highway and city and i have a 4cyl!!
It seems everyone who replied this is getting resonable mpg.
Postby icelove82 » Sun Mar 11, 2007 6:11 pm
icelove82
