SolaraGuy.com • View topic - Engine running to lean
Postby NCSolara » Wed Mar 07, 2007 5:51 pm
My engine is running to lean. Anybody know why by any chance. I havent touched my safc at all? I'm not to much of any engine guy :-?
NCSolara
Re: Engine running to lean
Postby ---CAMRAZY--- » Wed Mar 07, 2007 5:54 pm
NCSolara wrote:My engine is running to lean. Anybody know why by any chance. I havent touched my safc at all? I'm not to much of any engine guy :-?
Wait, first..... Are you a chick or a dude??? Seems like we get that a lot here......
I take it you are boosting? Whats your PSI? Have you done fuel upgrades?
Postby ClassySolaraGuy » Wed Mar 07, 2007 5:55 pm
^ LMAO........You both should be SG members. :)
ClassySolaraGuy
1 Rockin' Solara
1 Rockin' Solara
Postby NCSolara » Wed Mar 07, 2007 5:56 pm
I'm the husband. no boost running N/a modified. Just internals
PURT
NCSolara
Postby ---CAMRAZY--- » Wed Mar 07, 2007 5:58 pm
No need for SAFC....
Postby NCSolara » Wed Mar 07, 2007 6:04 pm
its not adjusted. I have forged pistons new valves. and thats i. I was driving yesterday and the scangauge2 came up with running to lean all of a sudden
PURT
NCSolara
Postby Sebas007 » Wed Mar 07, 2007 6:09 pm
a bit scary...you cannot use your car until you solve the problem..in my opinion. (you probably know that)
Postby NCSolara » Wed Mar 07, 2007 6:09 pm
and spraying but havent used nos in a while
PURT
NCSolara
Postby ---CAMRAZY--- » Wed Mar 07, 2007 6:19 pm
You need to get your ride tuned and get Jim's Fuel Upgrade, A walbro Fuel Pump....
Postby NCSolara » Wed Mar 07, 2007 6:56 pm
k
PURT
NCSolara
lean
Postby NRDriver » Wed Mar 07, 2007 7:34 pm
i would get it scanned and check out the o2 sensors. o2 sensors are the most likely reason
NRDriver
Postby DatSRBoi » Wed Mar 07, 2007 8:06 pm
You said you are not much of an engine guy yet you have forge internals? Did you do the work yourself? Maybe thats the problem there. I am not being mean so don't get me wrong, But maybe you should tell us more.
Postby NCSolara » Wed Mar 07, 2007 8:11 pm
i had a friend who is a mechanic do all the work
PURT
NCSolara
Running lean without boost
Postby PDX SuperSolara » Thu Mar 08, 2007 4:13 pm
I don't know what a "scangauge" is. I will assume it is either a wideband o2 sensor or a code reader for the ECU you used when you got a MIL. At any rate, I presume your car is a V6 since you are talking about no S/C. Is the mixture lean in both banks? If it is, it is likely something to do with that Safc you don't need or the MAF meter, these cars almost always go lean in one bank or the other because the banks are trimmed independently. If it is only one bank, check for vacuum leaks, especially around the injectors.
Jim @ Foreign Affairs
2315 SE 11th Avenue
Portland, Oregon 97214
503-236-2871
PDX SuperSolara
Postby NCSolara » Thu Mar 08, 2007 6:24 pm
PDX SuperSolara your the man, I think. I just read the code from my computer and its a 0171 which is bank 1 running to lean.
PURT
NCSolara
