SolaraGuy.com • View topic - Transmission Fluid Question
Postby PiterNYC » Mon Mar 12, 2007 6:30 am
I want to change my transmission fluid and I dont know which fluid to use, I know it has to be dexron III but does it matter if its Synthetic or regular, and can I mix them ?
Thanks
PiterNYC
Postby PiterNYC » Mon Mar 12, 2007 1:32 pm
Anyone knows ? :)
PiterNYC
Postby Paladin06Greg » Mon Mar 12, 2007 2:23 pm
It's never a good idea to mix fluid type. I suggest if you want to go Synthetic you have your transmission flushed and get the filter changed then service with the new Syn fluid.
Paladin06Greg
Torqued Solara
Torqued Solara
Postby orlin03 » Mon Mar 12, 2007 3:01 pm
You can also use anything rated higher than Dextron III, such as Dex IV, V, or VI. Each new Dextron is an upgraded (and more expensive synthetic) formula, but guaranteed to work in place of the older versions as well.
orlin03
