SolaraGuy.com • View topic - Suspension on 100K + mile Solara
Postby kaarona1 » Fri Mar 16, 2007 7:02 am
My 99 SLE has 120K miles and I have recently changed the rear struts and strut mounts. (Still knocking over bumps). Then I just replaced the sway bar bushing (Surprise, surprise.. Still knocking over bumps). The only thing that is left is the control arm bushings. My question is... how many people with high mileage Solaras have had to replace the rear control arm bushings and did it help?
kaarona1
Postby kaarona1 » Fri Mar 16, 2007 12:19 pm
bigity bigity bigity BUMP
Anyone?
kaarona1
Postby Ruski » Fri Mar 16, 2007 12:26 pm
Dude where do you live ?? im sure some Sg member can take a ride along with you b/c it seems like this suspension is kicking your a$$ my suspension is knocking every where too but i think its b/c it all loose and needs to be re tightened and replaced. which will be replaced with Tokico Hp instead of Monroe.. What set up do u have ??
Postby kaarona1 » Fri Mar 16, 2007 12:38 pm
This suspension is killing me, and my wallet. I have not lowered the car (although I should have since I replaced all struts and mounts). But I just have the Monroe Sensa-trak struts and all new mounts and new RSB bushings! I think I just need to drive this car off a bridge and call my insurance agent! oops!
kaarona1
Postby Ruski » Fri Mar 16, 2007 12:40 pm
THATS WHY !!!!!!!! You have flippin Monroe I have the same exact noise you are probably hearing its your struts i learned the hard way as well
Postby kaarona1 » Fri Mar 16, 2007 12:43 pm
I have the Sensa-Trac on front with no noises. This is a pain! I need a IS250. I live in South Bend, IN (Go Irish!)
kaarona1
Postby Ruski » Fri Mar 16, 2007 12:47 pm
then the rear is screwed.. my rear knocks like a jerk and front squeaks go get them replaced if they are under warranty at the store you got them from.. your top hat might be to loose here do this and tell me if it works.. pull the back apart i think you still might have your apart since you had this problem for a long time.. Get the right socket and tighten the top hat nut.. (the big nut in the middle off the hat ) tighten as hard as you can use a breaker bar if needed . make sure the strut poll dosnt spin which it shouldn't i did this and the knocking went away
Postby Ruski » Fri Mar 16, 2007 12:50 pm
check your pm
Postby kaarona1 » Fri Mar 16, 2007 12:51 pm
Thanks for the help man! Specs say tighten to like 36 lbs. I have it to like 70 and it still knocks. I think it will never go away!
So you dont think it has anything to do with the control arm bushings?
kaarona1
Postby facevedo17 » Fri Mar 16, 2007 1:24 pm
Time for coilovers ? just a suggestion don't pay me no mind
facevedo17
Postby kwyse » Fri Mar 16, 2007 6:12 pm
I just ordered new control arm bushing because mine are spent; the dealership told me they were worn earlier this week. I just need the rear one.
When I have the wheels turned hard, when theres a bump, or when I'm driving fast like on the highway theres a squeaking noise, I'd imagine from the metal control arm grinding on the frame with no bushing in between.
I dont know if this is what your noise is; control arm bushing is more of a squeaking though.
kwyse
Postby Ruski » Fri Mar 16, 2007 7:47 pm
dude check your pm and let me know if yes give a call after 2
