SolaraGuy.com • View topic - E-Ebrake
E-Ebrake
E-Ebrake
Postby Bravefan » Tue Mar 20, 2007 6:26 pm
I have searched this problem. My E-brake light is on, but brake is not on. The light stays on all the time. my fuel milage is less than normal as well. I checked my braking fluid it is fine and had my brakes checked by toyota a week ago please help me..
Bravefan
Postby MCOjerry » Tue Mar 20, 2007 6:28 pm
You had your brakes actually checked? I was going to say that perhaps the brakes were stuck in a partially closed (braking) position, but most likely not if you had it checked.
Did they check the whole braking system? Perhaps you have a malfunction somewhere else, other than AT the brakes.
Postby DatSRBoi » Tue Mar 20, 2007 6:30 pm
Just pour more brake fluid in and it will go away
Postby MCOjerry » Tue Mar 20, 2007 6:32 pm
He said he checked that already.
Postby kingkakyle » Tue Mar 20, 2007 8:24 pm
i thought he meant emergency e-brake, just in case his ebrake failed lol
Re: E-Ebrake
Postby QuickSEV6 » Tue Mar 20, 2007 8:27 pm
Bravefan wrote:I checked my braking fluid it is fine and had my brakes checked by toyota a week ago please help me..
Try topping it off. I think this is very sensitive.
My brake light was on so I went and bought a bottle of brake fluid. It only took about a tablespoon and the light went off.
Give it a try.
Postby Eye8Pussies » Tue Mar 20, 2007 11:18 pm
^ yup...can be very sensitive indeed.
a tablespoon of fluid will also make a difference in pedal feel as well.
Re: E-Ebrake
Postby PiterNYC » Tue Mar 20, 2007 11:23 pm
Give it a try.
Yeah I did the same thing and the light went away
PiterNYC
Postby Bravefan » Thu Mar 22, 2007 5:45 am
you guys called it. The brake fluid was low but not at the low mark. Thanks for help.
Bravefan
Postby mafioso » Thu Mar 22, 2007 1:22 pm
mine only does this when its cold... ever hear of that?
mafioso
