SolaraGuy.com • View topic - Driver seat wouldn't go back.
Postby Homerjay » Sat Mar 24, 2007 7:00 am
I just bought a 2000 Solara v4 w/ 61K miles for only $3700 salvage title so there's a few things wrong with it. I was hoping you guys can help me. The driver seat has power but only one side of the seat (right) would go back so it looks crooked also. It makes a grinding noise if i try to force it more.
Now I'm not a tall guy (5'8") and its not comfortable for me.
Homerjay
Postby unbalancedwood » Sat Mar 24, 2007 7:43 am
There is a flexable metal rod, covered in rubber, about 8" long that located near the front, if its not there or poped out then thats your problem.
Happened to me, pushed my seat all the way forward where a pair of shoes were and it ran them over, poping it out.
It will be a lot easier taking the seat out (4) bolts, and unplugging a wire connector or two. and poping it back in. You will have to bend the rod a lot, might look like its gonna break but i think its pretty flexable...hopefully its there, otherwise check a junk yard.
unbalancedwood
Postby Homerjay » Sat Mar 24, 2007 8:37 am
Thank you so much. That was the problem after all. I forgot to mention i found an odd looking rod under the seat but didn't think anything of it.
Homerjay
Postby unbalancedwood » Sat Mar 24, 2007 8:57 am
You'll see two small square looking female points where the bar goes in, the bar goes in from left to right along the car...not front to back.
You'll see it. Put one end in, then bend the other end till you get it to go in.
unbalancedwood
Postby lilm » Sun Mar 25, 2007 11:23 pm
sounds like you are missing two cylinders..........how does the v4 sound?
lilm
Postby unbalancedwood » Mon Mar 26, 2007 1:31 pm
^wrong thread?
unbalancedwood
Re: Driver seat wouldn't go back.
Postby **PoshPepper** » Mon Mar 26, 2007 2:12 pm
lilm111 wrote:sounds like you are missing two cylinders..........how does the v4 sound?
unbalancedwood wrote:^wrong thread?
Haa haa, he was just pointing out how he said v4 in his description of the car...
Homerjay wrote:I just bought a 2000 Solara v4 w/ 61K miles
LOL :drinking:
The Original... SOcalLARA
Milt's OTHER ride
**PoshPepper**
