SolaraGuy.com • View topic - Spark Plug Question
Spark Plug Question
Spark Plug Question
Postby SolaraGuy22 » Sun Mar 25, 2007 2:34 pm
I'm about to buy a set of Denso PK20TR11 spark plugs and wanted to know if that'll be okay with my CPE?
I know some of you guys mention using IK20 or even IK22 for modified rides. I've searched and I'm about to go nuts with all the threads so I figured I'd add another one.
I only ask because of the sticker on my hood:
Does that mean I can only use the PK20TR11
Thanks
-Anthony
SolaraGuy22
SolaraGuy Pimp
SolaraGuy Pimp
Postby unbalancedwood » Sun Mar 25, 2007 10:15 pm
I just bought some of those PK20TR11's (IR20s) on ebay for $36 shipped, for six. THey will work with the IMZ's and Im sure they will work with your CPe, dont know why not.
Denso K20TR11 ~$2.25 and NGK BKR6EKPB-11 ~$11.70 are also multi-ground plugs...
unbalancedwood
Postby Midias » Mon Mar 26, 2007 7:40 am
I am using NGK iridium IX single tips with my CPE no problem
Postby QuickSEV6 » Mon Mar 26, 2007 8:06 am
I have a suggestion.
NGK BKR6EQUP 3199
http://www.sparkplugs.com/results_cross ... &x=48&y=19
Postby unbalancedwood » Mon Mar 26, 2007 1:30 pm
Why twin tip spark plugs? and how can we use single tipped?
unbalancedwood
Postby SolaraGuy22 » Mon Mar 26, 2007 10:35 pm
Midias wrote:I am using NGK iridium IX single tips with my CPE no problem
Do you have the same sticker on under your hood? I think they might have changed it up when they went to gen 1.5 but who knows.
LMK because I'm going to be buying one or the other tomorrow night!
SolaraGuy22
SolaraGuy Pimp
SolaraGuy Pimp
Postby Midias » Tue Mar 27, 2007 4:47 am
No sticker but factory was denso double tip. I went bosch double tip for a short amount of time but they were no good. I wend NGK irridium becaust most high end cars use them no problem. I have about 15k on them now.
Postby crispone » Tue Mar 27, 2007 7:12 am
IGNORE the sticker!
DON'T use platinum if you want BEST performance... (they just LAST longer than conventional plugs, but DON'T conduct as good as copper, iridium, or SILVER.)
NO issues with CP-e.
Transverse mounted V6 cars are usually HARDER to service due to the difficulty in reaching rear-bank of plugs. SERVICE MANUALS set the recommended SERVICE INTERVAL accordingly, FURTHER APART, thereby necessitating the STICKER requiring PLATINUM or LONG LIFE plugs...
Just don't wait a million miles to change your plugs. You can use ANY proper length/thread plug of good quality and correct temperature rating that way.
My personal opinion... STAY AWAY from GIMMICKS like SPLITFIRE/MULTI-GROUND, etc, etc....
DENSO
NGK
BERU
Are some good brands to stick with...
I consider the BERU SILVERSTONE plugs as OUTSTANDING, but have ONLY used them on my SUPRA to date. They DO NOT last as long as other plugs, but with my hot ignition setup in an INDUCTED car, they brought NOTICABLE HORSEPOWER AND RESPONSE GAINS! :o
^^^ I don't know if there is a SILVERSTONE suited for out SOLARA, but when I change my plugs soon, if there IS, I'm using them FOR SURE.
Postby RichD978 » Tue Mar 27, 2007 7:23 am
i think someone is selling denso ik22's in the FS forum :wink:
RichD978
