SolaraGuy.com • View topic - Tool to fill transmission oil on a 5 spd 99 Solara V6?
Postby PTSOLARA » Wed Mar 28, 2007 12:35 am
I have a 5 speed Solara V6.
My transmission oil is leaking from the gasket (slow leak). Mechanic said it will take a lot of labor to fix this issue (something like taking the transmission out and reseal). So i was recommended to hold this off until i am ready to perform other major transmission work (like replacing the clutch).
In the mean time, i want to make sure i have enough fluid in the transmission. I have located the trans fill plug under the engine. But....how do i get the fluid into the transmission? The fill plug sits vertical to the ground and i think i need some sort of a tube to force the fluid into it.
Help!!!
1999 Solara SE V6 Red 5 speed Sports Ed.
Tokico/Eibach Whiteline FSB/RSB Ingen
PTSOLARA
Postby SC V6 » Wed Mar 28, 2007 6:01 am
What I do is unplug the filling hole... then locate the breather on the top of the transmission that can be seen from the engine bay... I took that out and filled from the top till it came out the fill hole
SC V6
Postby Midias » Wed Mar 28, 2007 7:29 am
I used a squease bottle and shot the gear oil into the fill hole but I like the breather idea
Where is the breather?
Postby PTSOLARA » Wed Mar 28, 2007 9:21 pm
SCV6, Do you have pictures of where that breather thing is? (sorry i don't work on my car that much).
This sounds like a plan. If that doesn't work then i will use Midias' idea of squeezing oil into the fill hole.
How do you know it is full, do you fill the oil till it leaks out?
PTSOLARA
Re: Where is the breather?
Postby Midias » Thu Mar 29, 2007 5:45 am
PTSOLARA wrote:SCV6, Do you have pictures of where that breather thing is? (sorry i don't work on my car that much).
It is full when fluid comes out of the fill hole
