SolaraGuy.com • View topic - Bad alternator....I think?
Postby solaraluv » Sun Apr 08, 2007 7:34 pm
Ok, It just took me like two hours to get home because my car had died about 10 mins after I started it up and jumped on the highway. At first everything seemed to be ok until i noticed the clock and the gauges began to get very dim and then all the indicators on the dash lit up then the CEL came on. I dove to the next exit the car started to loose power and felt like it wanted to stall out but the car continued to run for about another 5mins or so then it died. I got a jump the car starts right back up with no problem but again the same problem happend after about 10mins of driving and I had to jump it again. 'on my second attempt I drive about two miles or so and it starts to die agian and out of no where the lights start to flicker a bit then they get bright as if there is nothing wrong but the cel is still on?? Im very confused.
Loved by few hated by many
solaraluv
Postby woa_its_j3ff » Sun Apr 08, 2007 7:35 pm
deleted.
Postby woa_its_j3ff » Sun Apr 08, 2007 7:36 pm
quit triple posting. just hit the 'submit' button once. and yeah i had the problem before on my buddy's car. it turned out to be a dying alternator. go get it checked out.
Postby solaraluv » Sun Apr 08, 2007 7:43 pm
^^^Sorry about the triple post I tried to delete before anyone would notice but the alternaor is whats causeing the check engine light?
solaraluv
Postby woa_its_j3ff » Sun Apr 08, 2007 7:55 pm
honestly dude I think it is the alternator. I had a post up on sg about a similar problem in my buddy's Oldsmobile. the car would shake and shudder while driving and at a redlight the rpms would rev high and sometimes the engine woudl just die while sitting there, the lights would dim, everything.. and sometimes it seemed as if the engine was misfiring, it turned out it was a bad alternator. go check yours man. it could be it.
Postby ClassySolaraGuy » Sun Apr 08, 2007 8:05 pm
Sounds like the battery is not holding a charge. Have a few question's for you.
-Original Battery?
-Have you had the battery checked free at autobone?
-Clean & tight Terminals?
-Belts old? Possible slippage.
-Do you hear a whining when you drive under the hood when you drive? The pitch would range with what ever RPM your at.
-Anything you know of that could possibly be draining the battery while the car is on or off?
ClassySolaraGuy
1 Rockin' Solara
1 Rockin' Solara
Postby solaraluv » Sun Apr 08, 2007 8:15 pm
^^Its a Red top im using ive had it for about 2yrs now as for the belts I checked and they are ok and the whining sound i dont think ive notice but i will keep a close eye on that. I just remote started tha car from inside a Let the car run for a while it seems to be fine now but the engine light is still on.
solaraluv
Postby woa_its_j3ff » Sun Apr 08, 2007 8:17 pm
could be the blinker fluid. it might be draining a lot of power from your flux capacitor.. also make sure the connections are tight to, as the looser or not as fit as they should be, the more fluid gets drained. that might mess with your alternator..
Postby solaraluv » Sun Apr 08, 2007 8:17 pm
ClassySolaraGuy wrote:Sounds like the battery is not holding a charge. Have a few question's for you.
-Original Battery?
If it were the battery wouldnt the volyage light com on on the dash?
solaraluv
Postby ClassySolaraGuy » Sun Apr 08, 2007 8:19 pm
Same battery here too. I experienced whining from my alternator on my Jeep before getting it checked out. It was in fact bad & I had it replaced. I would have the battery checked out first just to make sure that its square before resulting to taking your alternator off & having that checked out.
ClassySolaraGuy
1 Rockin' Solara
1 Rockin' Solara
Postby solaraluv » Sun Apr 08, 2007 8:19 pm
woa_its_j3ff wrote:could be the blinker fluid. it might be draining a lotta power from your flux capacitor..
Blinker fluid!!!? whats that? or are you joking with me?
solaraluv
Postby ClassySolaraGuy » Sun Apr 08, 2007 8:24 pm
-Original Battery?
Not always
ClassySolaraGuy
1 Rockin' Solara
1 Rockin' Solara
Postby solaraluv » Sun Apr 08, 2007 8:29 pm
woa_its_j3ff wrote:could be the blinker fluid. it might be draining a lot of power from your flux capacitor.. also make sure the connections are tight to, as the looser or not as fit as they should be, the more fluid gets drained. that might mess with your alternator..
Please excuse my ignorance but what is blinker fluid? where is it located? is this something I can service myself?
solaraluv
Postby woa_its_j3ff » Sun Apr 08, 2007 8:38 pm
Change Your Blinker Fluid
http://www.geocities.com/changeyourblin ... luid1.html
honestly, blinker fluid does not exist..
it's either that. or could be bad battery but as you stated it seems like everything is alright with it.I still go with my first choice, alternator.
If all else fails, S15Lara could say blinker fluid (synthetic of course)..
maybe the flux capacitor but i'll have to get back to you on that..
Postby solaraluv » Sun Apr 08, 2007 8:54 pm
woa_its_j3ff wrote:Change Your Blinker Fluid
That car looked like a eclipse im not sure if the Solara has that (V6) or at least I have not noticed.
solaraluv
