SolaraGuy.com • View topic - check engine help.......
Postby SolaraBlue » Tue Apr 10, 2007 3:19 pm
my "check engine" light came on last night, so i did a diagnostic and it came up saying:
"SAI system incorrect downstream flow detected" code- p1411
AND
"the PCM has determined that there is excessive flow in the exhaust gas recirculation system" code- p0402
anyone know what the problem could be? thanks in advance!!!
P0402
Postby PDX SuperSolara » Tue Apr 10, 2007 3:46 pm
Excessive EGR flow could be caused by the EGR valve stuck open, a problem with the VSV which controls the EGR, it's vacuum or electrical circuit or control in the ECU. The EGR has a temperature sensor that reads the increase in temperature when the EGR is told to open. If the temp increase is not what it should be, in your car's case, it is going up too high indicating excessive flow, then it will set this code. My guess is that the EGR valve is sticking open.
Jim @ Foreign Affairs
2315 SE 11th Avenue
Portland, Oregon 97214
503-236-2871
PDX SuperSolara
Postby SolaraBlue » Tue Apr 10, 2007 3:58 pm
thanks jim!!!
does this mean ill need a new EGR valve or ECU?
any idea what the dealer is going to charge (rape) me to fix this?
Postby Paladin06Greg » Tue Apr 10, 2007 4:05 pm
Paladin06Greg
Torqued Solara
Torqued Solara
