SolaraGuy.com • View topic - Squeaky Gen 1 soilara door panel
Postby xcgames » Thu Apr 12, 2007 1:11 pm
Hi all, I have a habit of driving with my knee pressed against the driver side door and very recently, the entire door panel began squeaking with just a tiny bit of pressure to it. And when I'm driving on the twisting 110 pasadena freeway every day, this squeaking sound really drives me nuts, it makes my car sound like it's a piece of plastic junk that's falling apart...
What can I do do get rid of this panel squeak? thanks all...
xcgames
Postby anttarz » Thu Apr 12, 2007 1:12 pm
remove the panel, clean it out and put it back together securely
anttarz
Postby xcgames » Thu Apr 12, 2007 1:21 pm
i would do that but i don't have a guide. i probably can't put it back without one.
xcgames
Postby anttarz » Thu Apr 12, 2007 1:34 pm
anttarz
Postby lilm » Thu Apr 12, 2007 1:41 pm
ya its very easy....the guide there pretty much is all you do...just don t forget the little sail piece at the top
and don't strip any screws when putting it back in...i would hand turn them till you know they are ok.
lilm
Postby woa_its_j3ff » Thu Apr 12, 2007 1:45 pm
ive had that same issue ever since i got my window regulator replaced...
Postby xcgames » Thu Apr 12, 2007 1:56 pm
thanks for the guide. i found the plastic cover in the door completely fell off (the glue are too old). More things to do than fixing the squeak.
xcgames
Postby Mole » Thu Apr 12, 2007 8:08 pm
was that the cause of the squeak ?
