SolaraGuy.com • View topic - Solara auto > manual swap ?'s
Postby ReaDY-SeT-Go » Fri Apr 20, 2007 11:25 am
lilmike2069 wrote:Does anyone know a ballpark on how much it would be to swap out the automatic with the 6spd, or even the 5spd manual tranny on a MKIV supra? I want to buy a supra, but of the few that i'm able to find, they all seem to be auto and i'd much rather have the manual on a sports car.
Mole wrote:a lot easier to swap rather than teh solara
hey guys i just saw this and it really caught my attention... just being curious is it really that hard to swap the solara tranny?? i looked around on search also but i couldnt find anything... i know you'll have to get a rebuilt one never a used one and a syncros, tranny, clutch master and all that... i also heard its dangerous or something but... what if you guys were going to swap a i4 tranny to manual could you use the v6 tranny??
ReaDY-SeT-Go
Postby SpikedMantis » Fri Apr 20, 2007 12:39 pm
I believe they both use the e153 tranny.
This is the space where I should write something witty or clever, hoping to show some personality.
SpikedMantis
Postby ReaDY-SeT-Go » Sat Apr 21, 2007 11:31 am
is it still worth doing for a i4?? just so you know... it wont be that bad having a i4 solara and its auto... might feel a little better to have it in manual :D ... but im willing to spend maybe a low 1000+... what do you guys think im looking at for everything??
ReaDY-SeT-Go
Postby Eye8Pussies » Sat Apr 21, 2007 11:52 am
lol...the supra doesn't use the e153...hahah....
but back on topic...
If you want to do it the ghetto way with an older tranny and stock clutch, flywheel (resurfaced), then you can do the swap for low 1K for sure. presuming you do the labor yourself.
if you want to go performance components, the clutch and flywheel will cost you close to 1K itself (I'm talking canadian dollars on this one)
Postby SpikedMantis » Sun Apr 22, 2007 2:26 pm
Eye8Pussies wrote:lol...the supra doesn't use the e153...hahah....
ReaDY-SeT-Go mentioned swapping the I4 with V6 tranny. Last time I checked, Supras have an I6 engine, so I assumed he was talking about V6 Solara.
Someone on the boards have swapped their I4 auto to a manual, but I'm not sure which tranny they used.
SpikedMantis
Postby Eye8Pussies » Sun Apr 22, 2007 9:07 pm
on the supra boards, or on the solara boards?
the solara and camry can both use the s54 or the or the e153. the i4 can use both, while the v6 can also use both, but it's not recommended as it wasn't designed to hold that much torque for too long (otherwise they wouldn't have designed the e153 for the v6). as well, the gearing on the s54 is shorter
Postby SpikedMantis » Mon Apr 23, 2007 10:49 am
Eye8Pussies wrote:on the supra boards, or on the solara boards?
On this forum. Gen1.5 auto swapped to manual.
SpikedMantis
e153
Postby 2az-KRN » Mon Apr 23, 2007 6:26 pm
is the e153 out of tC as well??
I'm just curious if I can take a stock tC manual tranny from junk yard and swap it into my 2Az...
Also, why are we talking about putting supra tranny into solara?
Look, Supra is RWD, and Solara is FWD. tranny for RWD will never be able to fit into FWD.
2az-KRN
Postby DatSRBoi » Mon Apr 23, 2007 7:10 pm
Honestly just buy a darn solara with a manual tranny if it does come with them.. Why put all the time when you can sell your car and buy another one the way you want.. If you say because of your parents then I doubt they going to enjoy it when you spend money to convert the car.. Just sell your dam car. Saves time and easier.
Postby Eye8Pussies » Mon Apr 23, 2007 11:03 pm
the only cars that use the e153 is the solara, camry and the mr2 turbo
and lots of people with camrys have done it.
as well, I agree with Dats...unless you've already done a lot to your car, it's easier to just pick up a solara w/ a 5spd.
I'm swapping only because my car never came with a 5spd. and the s/c wasn't made for it either...it's good to be unique :p
Postby ReaDY-SeT-Go » Tue Apr 24, 2007 1:13 pm
so how would you go about to get everything done?? is it pick up a new e153 tranny and take it to a reliable shop and just be like "hey can i get this swapped in" or if you go to a shop you can ask them to do it and they'll just bill you?? cause i was thinking about asking my cousin to get it done for me and i was just gonna supply him with the parts but im just not sure... what i'll need... is there a list or anything?
ReaDY-SeT-Go
Postby 2az-KRN » Tue Apr 24, 2007 8:06 pm
Well i already thought about buying a different solara with manual. duh...
i got 2003 solara with auto and i can't seem to find 1.5 gen solara with manual tranny
i don't want to get a 1.0 gen
2az-KRN
Postby 2az-KRN » Wed Apr 25, 2007 4:18 pm
ballpark figure of what you'll need
1. the tranny- duh..
2. clutch pedal, etc..
3. clutch line
4. slave cylinder
5. new ecu from a manual solara
i am sure there are other things just can't remember them right now..
also you might wanna get new flywheels, clutch, synchros, and gears.
2az-KRN
Postby Eye8Pussies » Wed Apr 25, 2007 8:20 pm
^?? new synchros/gears?? if you're going to rebuild the tranny while you're at it, then sure
also a master cylinder and shifter cables
no need for an ecu- all you have to do is trick the auto ecu
otherwise, that's about it....and if the tranny doesn't come with mounts, then a manual tranny mount as well
Postby ---CAMRAZY--- » Wed Apr 25, 2007 8:32 pm
Shifter, shift cables, master cyl, slave cyl, manual v6 axles, flywheel, clutch, e153 tranny from 99-02 solara, tranny mount (you also need a bracket for the tranny mount), pedal assembly, (also try to get a manual ECU for the car so you will not get a CEL, I got mine for 100 bucks or trick it like King said, but now I am back to having a auto ecu and had to make a resistor box with the new engine wire harness, lol), pedal assembly. That is all I can think of for now.
Man I have posted this like 100 times now...... lol
Here and TN
