SolaraGuy.com • View topic - Warming up the car
Warming up the car
Warming up the car
Postby Dawgz » Tue Apr 24, 2007 2:19 pm
OK so how long are u suppose to warm up the car before u drive off? i usually let it run for 5-7 minutes, but i read online in some artical that only 30 seconds is good enough.
How long do you guys let the car warm up?
Postby Jai_Jai_Binks » Tue Apr 24, 2007 2:22 pm
You will never get one common answer to this question! Depending on people's tastes and styles you will get different answers.
warm up for 5-7 minutes is too long!
ME: i usually, start the car, then go and get the newspaper from the driveway (either take out the trash/recycling), get in the car, remove my wallet and place it aside in the car, tune my radio and drive off (its like a minute or two max). The temp is close to that bottom bar of "C" by then.
Regardless of what you hear from me and others - its critical to keep your rpm's down till you reach optimal temps'
Postby NeFaRiOuS_SLE » Tue Apr 24, 2007 4:31 pm
Personally I let it run for about 15 seconds and take it easy until it's warmed up... That way the other components of the car gets warmed up as well; no point in letting it run for 2 minutes if your steering system and whatnot are still room temp. cold IMHO.
Postby camry_101 » Tue Apr 24, 2007 4:37 pm
i let it run till the the arrows in the middle 5 mins i got remote start so i start while im still inside lol
camry_101
Postby bronzemaxell » Tue Apr 24, 2007 4:42 pm
i normally warm up my solara for 1 or 2 seconds, then drive.
i was told by someone who have driven vehicle 30 or 40 years, he said unless it is in a real cold weather like winter in maine, it is not necessory to warm up the vehicle.
bronzemaxell
Postby DaTwUnKrAziEpInOy » Tue Apr 24, 2007 4:43 pm
I usually warm up my car for about 2-3 minutes or atleast one track on a cd. :P
DaTwUnKrAziEpInOy
Postby MCOjerry » Tue Apr 24, 2007 5:51 pm
I don't warm up my car at all. I turn it on, put the seatbelt on and go.
Postby Sentinel » Tue Apr 24, 2007 6:17 pm
as long as you drive easy untill the car is getting warm, you don;t need a warmup
Sentinel
Postby ThatVietGuy » Tue Apr 24, 2007 7:36 pm
Most modern cars don't really need to warm up. It's why the auto's don't shift out of 2nd until the meter is above the C
ThatVietGuy
Postby Yanks0114 » Tue Apr 24, 2007 8:34 pm
agreed that it isn't necessary to warm up the car if you are easy on the throttle.
ThatVietGuy - the car actually stays in a lower gear to keep the RPMs up in order to warm up the emissions equipment (cat converter).
Postby CosmicGrooves » Tue Apr 24, 2007 9:02 pm
I warm up for at least 30 seconds. In cold weather, a bit longer depending on how cold.
CosmicGrooves
Postby blaK » Wed Apr 25, 2007 9:32 am
Good question, I wondered about this also. I'm in FL. so there isn't much warming up to do.
blaK
Postby DatSRBoi » Wed Apr 25, 2007 9:34 am
Depends on weather as simple as it is. Warm days 30 seconds. Cold days 1 minute. On freezing days 1 minute and 30 seconds to 2 minutes. Should never need to go over that unless your running pure water in your radiator.
Postby woa_its_j3ff » Wed Apr 25, 2007 9:35 am
Winter: i warm up until that temp gauge is in the center which can take at least 10 minutes.
Summer: i dont even "warm up"
Fall: about 10 secs.. after I turn on the iPod in the car
Spring: same as summer, don't warm up at all..
Postby Sebas007 » Wed Apr 25, 2007 9:40 am
Winter warm-up should be 1 minutes max...to get the oil get a normal temp. Even so, the time to "unsnow" the car...it takes me at least 1-2 minutes.
Summer I do a 30 second warm-up
the purpose here is to give time to fluid to make their job before going. It doesn't take long....old car with heavy iron engine were slower to warm-up
Users browsing this forum: Google [Bot] and 10 guests
