SolaraGuy.com • View topic - timing belt question
Postby aleki2424 » Fri Jun 22, 2007 8:04 pm
hey, i was wondering. is it a fact that OEM parts are always the 'best' choice for replacements? especially basic parts such as the t-belt. reason being that i am getting ready to replace mine, and i remember something about OEM belts not doing to well at high RPM's and messing the ignition?
just wanted input from pple who have aftermarket engine parts , and how they performed in the period....
aleki2424
Postby ozone » Sat Jun 23, 2007 10:06 am
It's my opinion that most of the time, choosing OEM parts is a good idea. But there are some areas where the aftermarket outperforms the manufacturer and there are definitely times when the manufacturer has really lousy parts. The clips that hold down the front trunk (frunk) lid of my Spyder, is a good example. It all depends on the part.
As far as timing belts go, I can't say. I am doing my timing belt as we speak and I got a Toyota belt. I'd like to know as well if anyone has any knowledge as to the poor quality of the Toyota belt.
I kind of doubt there is any problem, myself.
ozone
Postby aleki2424 » Sat Jun 23, 2007 2:19 pm
thanks OZONE. anyone....??
aleki2424
Postby (K) » Sat Jun 23, 2007 8:04 pm
Agreed, OEM is USUALLY the best way to go but not always. Even though I am an OEM freak there are times when I admit there are aftermarket manufacturers that just plain outperform and outlast.
Timing belt though, you can go either way. I recently got mine replaced as well and I went with Toyota's ($40 from the dealership). Overpriced? Heck yes. Could I have gotten it cheaper elsewhere? Heck yes. But I needed it last minute so I did what I had to do.
Messing up ignition and not working too well at high rpm I'd be skeptical about, never heard that one and I don't think I believe it much. I doubt Toyota would overlook something as vital as that.
(K)
Postby 99V6solaraSE » Sat Jun 23, 2007 8:16 pm
well if you're getting OEM through toyota, you can kinda have good faith that it wont mess up and its under a 12 month warranty. If your brought in parts, they told me that it wouldnt be covered under that warranty.
and in the same way i didnt really have the time to look into it as much. Nor did i think it mattered to me as much.
99V6solaraSE
Postby ozone » Sun Jun 24, 2007 7:01 pm
Here's a good reason to use the OEM timing belt:
See the timing marks on the belt where the arrows point? Theres a third one on the backside. Do aftermarket belts come with these marks?
ozone
Postby deus85 » Sat Jul 21, 2007 6:06 pm
The aftermarket OE one I got off azautohaus.com has those marks.
deus85
Postby ozone » Thu Jul 26, 2007 8:22 pm
Yeah, now that I've done the timing belt replacement, I realize that the aftermarket belts HAVE to have them, otherwise you might be off by one tooth. My bad.
ozone
Postby TadS » Fri Jul 27, 2007 7:32 pm
I usually use Goodyear belts, timing and serpentine. I don't think I would want to go with cheaper aftermarket, especially with the timing belt, just for piece of mind if nothing else. Granted OEM is usually a safe bet also.
TadS
Postby Dawgz » Fri Jul 27, 2007 7:34 pm
my car has 81k or somewhat on it, its a v6, when is the regular timing belt service for it?
Postby Americanctm10 » Fri Jul 27, 2007 9:47 pm
Should be replaced at about 100k
Americanctm10
Postby Dawgz » Fri Jul 27, 2007 9:48 pm
cool
Postby mazen222 » Sat Jul 28, 2007 1:27 pm
i thought its 90 miles or 144km... thats what i read from maintenance manual
camrymanuals.com
mazen222
Postby Jai_Jai_Binks » Sat Jul 28, 2007 1:47 pm
it generally depends on how you drive - if you feel your car is more city driven, then replace it sooner, if you feel your car is mostly highway driven, then you can take it too 100K. I had my camry done at 60 and my solara at 88K. Call me neard, the only reason i did my solara is could i could hear the difference when it was time to get it done.
Postby Ruski » Sat Jul 28, 2007 2:14 pm
^^ what did it sound like when it needed to be changed ? Im at 89K
