SolaraGuy.com • View topic - Door Window Leakage
Door Window Leakage
Door Window Leakage
Postby Guest » Tue Apr 22, 2003 3:55 pm
Just wondering if anyone ever gets small amounts of water leaking through the door window seals. This sometimes happens to me when I wash my car with the hose. A few drops sneak between the glass and seal...
Can I do anything to prevent this?
Guest
Postby AtomicPunk » Tue Apr 22, 2003 4:16 pm
I et some leakage around the side mirror, or the top of the window. This only happens when I wash with a pressure hose. No bog deal - I just gry it up.
Todd
AtomicPunk
Postby Yanks0114 » Tue Apr 22, 2003 4:24 pm
I get the same thing. As long as it doesn't happen when it rains it shouldn't be a big deal. Just don't use so much pressure around the glass
Postby pecora55 » Tue Apr 22, 2003 8:31 pm
yea i get it when i go through the no touch washers, but not from rain, u get used to it, sometimes it doesnt happen
Goodbye solara, loved you while i had you :( now into my bros hands, and hello Spec V...BYE BYE SpecV HELLO 04 Maxima ;)
'04 Maxima SE
'03 Sentra SpecV(SOLD)
'99 Solara SLE V6 Auto(SOLD)
pecora55
Postby NASTY » Tue Apr 22, 2003 8:40 pm
hmmm, never
ill double check, although im sure its never leaked
(make sure your windows closed all the way!)
'01 SLE V6
NASTY
Postby Flipside909 » Tue Apr 22, 2003 9:52 pm
I've never had that problem. But yes, water streams shouldn't be directed at those parts anyway considering there is no door frame around the windows. The seal there isn't that great at all.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby krook » Wed Apr 23, 2003 2:33 am
when you wash your car the manual says to wash your windows by spraying at them at a 45 degree angle, upwards. i do that, and i still don't get any leakage.
make sure your windows are all the way up...? not too sure what to tell ya.
krook
Postby happy_aggies » Wed Apr 23, 2003 8:42 am
If you spray straight w/ strong enough pressure, it will leak up a bit.
Pretty normal and make sense.
happy_aggies
Postby CrazyCraig » Fri Apr 25, 2003 3:53 pm
Not only does water enter via the side mirrors, but dust is also a real pain in the butt! Combine the two, and you've got mud. :-?
CrazyCraig
CrazyCraig
Postby 4banger » Tue Apr 29, 2003 4:26 pm
I used to get it all the time with my 90 celica (no window frame either) at the car wash. but never with my solara.
Silver '99 Solara SE 4cyl.
4banger
