SolaraGuy.com • View topic - Dissapointment
Dissapointment
Dissapointment
Postby kubi » Sun Apr 27, 2003 5:46 am
So I was very dissapointed in my baby yesterday, a 2002 with 40k miles. I drove down to Dallas from Kansas City, and about 45 minutes outside of Dallas I noticed my check engine light was on. I also noticed the area near my feet was becoming very warm. The engine temperature was fine, so I pulled over to see what I might find out. Nothing out of the ordinary. I tried disconnecting the battery, however the check engine light remained on. I attributed this to the fact that the car was still pretty warm. I let the car cool down for an hour or so, then headed on towards Dallas where I found the nearest Auto Zone. The guy there told me the problem was with the catalytic converter. After resetting the check engline light it did not come back on, of course the car had been sitting for 1 hour, then driven for half hour, then sitting for half hour, again. I drove around for a while and everything seemed to be fine. Drove downtown, drove back, everything was fine. As a result of this, I decided to end the trip early. Driving back to Kansas City I made it within an hour when I noticed the check engine light was back on. The area around my feet was warm again, however not nearly as hot as it was the first time. Shortly after smoke began to come from the driver's side at the back of the hood. When I pulled over, however, the smoke immidiately stopped. When idling the smoke did not appear, nor when reving the engine in neutral. I had my friend rev the engine while I checked the exhaust, which I discovered was sputtering. My best guess was that the smoke coming from the hood was not actually smoke but exhaust? After letting the car cool for some time and then driving again the "smoke" reappeared after several minutes, however then it dissapeared again.
So.... any ideas?
kubi
Postby sliver 2 » Sun Apr 27, 2003 7:52 am
bring it to ur dealer and hav it check
sliver 2
Postby kubi » Sun Apr 27, 2003 7:58 am
sliver 2 wrote:bring it to ur dealer and hav it check
Wow I never thought of that, thanks!!!!!
kubi
Postby kubi » Sun Apr 27, 2003 8:49 am
Ya... well I think I figured it out, I'm fairly upset at the moment.
kubi
Postby happy_aggies » Sun Apr 27, 2003 9:04 am
What is the problem?
happy_aggies
Postby Mole » Sun Apr 27, 2003 9:11 am
radiator leak? @40k the car should still be under waranty.
Postby kubi » Sun Apr 27, 2003 9:12 am
Blown gasket on the exhaust manifold is the current theory.
kubi
Postby kubi » Sun Apr 27, 2003 9:13 am
TRDMole177 wrote:radiator leak? @40k the car should still be under waranty.
The engine temperature stays stable. The heat is a result of the exhaust blowing on the firewall.
kubi
Postby Mole » Sun Apr 27, 2003 9:16 am
at 45k, i had a leaking head gasket. however in your spot a blown exhaust gasket does not sound too bad.
Postby kubi » Sun Apr 27, 2003 9:23 am
Now I'm not so sure anymore... because I could see the exhaust coming out... and then it stopped... and then it started again, and then it stopped.
kubi
Postby Turbosolara » Sun Apr 27, 2003 10:51 am
If you see your enigne bay that has exceed oil kind of dirt on your component, then it must be exhaust.
and what is your check engine code?
Is your car 4 cylinder or 6?
Do you smell oil burn while you driving?
Postby Fairlite » Mon Apr 28, 2003 6:17 am
kubi wrote:Now I'm not so sure anymore... because I could see the exhaust coming out... and then it stopped... and then it started again, and then it stopped.
Well my opinion then is instead of didling with it to figure out what is wrong just bring it to the dealer.
2000 Solara SLE
Toyo Proxies TPT
Alpine 7878 CD/MP3 Headunit, Alpine XM Radio, Alpine 6 Disc MP3 Changer, JL 300/4 & JL 500/1 Amplifiers, 2 Sets of Boston Pro 6.5 Speakers, Boston Pro 12.5LF Sub-Woofer.
Fairlite
Postby kubi » Mon Apr 28, 2003 11:44 am
It's AT the dealership. I just like to know what is happening with my things, you know?
kubi
Postby Fairlite » Tue Apr 29, 2003 11:39 am
I know but when it start coming to "I think I know" then to "well maybe it's not" :) I would just give up and let someone tell me. Car's are to weird sometimes to pinpoint anything.
Oh and by the way did you fond anything out?
2000 Solara SLE
Toyo Proxies TPT
Fairlite
Postby kubi » Tue Apr 29, 2003 4:25 pm
One catalytic converter, one exhaust manifold gasket, one oxygen sensor, and one air fuel sensor later all is better.
kubi
