SolaraGuy.com • View topic - the solara's.....day time running lights,,,(the headlights);
Postby trdsolara08 » Fri May 02, 2003 7:43 pm
I was wondering ,,,if there;s a wayto turn off the the day time saving lights for the headights....because,,i already burnout two lights..and it's a pain in the neck to replace it...so he anyone knows how to..let me know...please..it will help...thankz...TRD here....
trdsolara08
Postby Peter » Fri May 02, 2003 8:00 pm
i thought i told u already?..... just unplug the gray plug by the yellow sticker on the top left of ur engine bay. then cover it up w/ some electrical tape
Peter's "Black Sheep"
Visit Black Sheep
Peter
Postby krook » Fri May 02, 2003 8:04 pm
peter's right. did you pm him before?
krook
Postby krook » Fri May 02, 2003 8:20 pm
here trdsolara08:
http://www.pbase.com/image/223871
at the top LEFT of the engine bay, see those two plugs? unplug the gray one. (pic courtesy of Blaze) :P
krook
Postby j0hn » Fri May 02, 2003 9:50 pm
sigh.......haha.... since i never really did have any luck with that "gray connector"...jus do this... before you completely lower your e-brake...leave it one notch up. Your ebrake is still disengaged but the sensor is still off while you drive. Havent you noticed that your DRL's turn on when you put down your e-brake?. hope this helps neone.
Later
j0hn
Postby Flipside909 » Sat May 03, 2003 1:44 am
j0hn wrote:sigh.......haha.... since i never really did have any luck with that "gray connector"...jus do this... before you completely lower your e-brake...leave it one notch up. Your ebrake is still disengaged but the sensor is still off while you drive. Havent you noticed that your DRL's turn on when you put down your e-brake?. hope this helps neone.
Later
that's the stupidest way to keep your DRL from coming on. Do it the right way, unplug the gray plug.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby Peter » Sat May 03, 2003 1:46 am
yeah....thats probably the worst way to do it.... how hard can it be to find that plug?
Visit Black Sheep
Peter
Postby 01RDSLE » Sat May 03, 2003 7:06 am
if you try this at dusk or in a dark garage, the lights will still pop on because of another sensor that does just that. Trust the gray connector disconnect. it works!
Wishin for warmer weather!!!
01RDSLE
Postby Flipside909 » Sat May 03, 2003 8:10 am
01RDSLE wrote:if you try this at dusk or in a dark garage, the lights will still pop on because of another sensor that does just that.
Yup, thats where you can disable the light sensor located at the passenger side nearest the windshield.
www.clublexus.com
Flipside909
Postby WTF?? » Sat May 03, 2003 11:47 am
krooked Solara wrote:here trdsolara08:
hey what do you have right underneath your coolant?? Isnt there a huge gap there originally?
Retired... its been fun Image
WTF??
Postby Mole » Sat May 03, 2003 12:43 pm
i believe that is the abs?
Postby krook » Sat May 03, 2003 1:58 pm
solara nytez wrote:hey what do you have right underneath your coolant?? Isnt there a huge gap there originally?
you mean the coolant recovery tank?? that's on my car, and mines a V6....Blaze's one is a i4. i'm pretty sure it's supposed to be there.
ask Blaze though, it's his car.
krook
Postby xyntax » Sat May 03, 2003 11:08 pm
Now I understand why we dont have that in our 02-03 Solaras. Nobody here with gen 1 likes it :)
-~=| XYNTAX |=~-
2AZ-FE & 13B-MSP
xyntax
Postby j0hn » Sat May 03, 2003 11:48 pm
Hmm...ryte, I know you are respected in this community of Solara drivers flip, but I don't like how you totally dissed my method for disengaging the DRLs. I felt that it was totally unprofessional coming from an individual that stresses professionalism. I know Im being a little pretentious, but I pride myself in the whole, E-Brake thing, certainly others have discovered that already, but that is beside the point. I mean, some people out there just might be unwilling to go under their hood and pop off that gray connector coz their afraid to jack something up.
I know said I had a little trouble with my connector. It was only because when I took mine off, my lights turned on all the way and I couldnt switch it off. I just hope no emnity stems from this post, I just wanna say something back.
j0hn
Postby krook » Sun May 04, 2003 12:09 am
hey john,
1st. please register. you could have taken this to pm if you wanted to say something back. you don't need to prove anything to us.
2nd. flip's responses are usually like that. we've become accustomed to it. actually, i kinda like it...in some...sick, sort of. way.
3rd. unpluging that gray connector WILL NOT 'jack anything' up. it's much more safer to unplug something, than it is to drive with the e-brake even SLIGHTLY up. i'd rather unplug something to take care of the DRL.
krook
