SolaraGuy.com • View topic - Chair clicking noise
Postby Guest » Thu Apr 25, 2002 5:27 pm
When I drive by myself, with no one sitting in the passenger seat, the passenger seat will sometimes make a clicking noise, especially if the road is bumpy or I'm going fast. I can usually play around with the seat and it will stop, but it gets really annoying. Anyone have a similar problem or know how to fix it?
Guest
Postby Guest » Mon May 06, 2002 3:10 pm
Yes i get the same sound out of my solaras Sle. I took it into the dealership and they replaced the sliding track didnt help...ever figure out what it is?
Guest
Chair knocking
Postby GUEST » Tue May 07, 2002 6:17 pm
Don't laught. One day coming home from the cleaners, I hung the dry-cleaning on the headrest posts and the clicking stopped. Temporary solution, hang something from the back.
Poor design Toyota!
Mike
GUEST
Postby TITO » Fri May 10, 2002 9:38 pm
Yes! Mine does it too. And if you put your hand on the seat, you can feel the vibration that is causing that noise. Must be something loose on the mounts?
TITO
Postby Guest » Sat May 11, 2002 9:27 am
It seems like if I put the seat all the way forward, it will stop making the noise or at least make it somewhat better. Still, it's pretty annoying. Maybe I'll take it to the dealer.
Guest
Postby Jaimster » Mon May 13, 2002 9:08 pm
I just put the seat all the way back...that usually works.
Jaimster
Track is too big
Postby solara_man2000 » Fri Sep 05, 2003 7:42 pm
After careful analysis, I've figured out the loose seat problem on the passenger's side. It's the little track that the seat sits in on both sides. The track appears to be too large for the sliding wheels of the seat. When the seat is all the way forward, the rear wheels are only in contact and the problem is solved. But who drives with the passenger seat all the way forward?
I think the problem could be solved by removing the seat and then removing the track and replacing it with a new track that is tighter.
Now where can I get new tracks????
solara_man2000
Postby Turbosolara » Sat Sep 06, 2003 1:56 am
Since its a defect, can we request toyota to recall?
Postby DavPak » Sat Sep 06, 2003 6:49 am
UltraslowSolara wrote:Since its a defect, can we request toyota to recall?
haha, good luck! :lol:
techinically toyota has never had a recall. only "Special Service Campaigns." the only car manufacturer with that track record.
'02 Solara S/C'ed V6 5-spd
DavPak
Ignore problems
Postby solara_man2000 » Sat Sep 06, 2003 11:21 am
It's probably cause they ignore these little, although annoying problems.
solara_man2000
Re: Ignore problems
Postby DavPak » Sat Sep 06, 2003 11:28 am
solara_man2000 wrote:It's probably cause they ignore these little, although annoying problems.
way off base. toyota is probably the pickiest car manufacturer out there. no other manufacturer pays as much attention to squeeks, rattles, wind noise and the like. go drive some other cars for a small period of time, you'll appreciate your toyota more.
DavPak
Recall
Postby solara_man2000 » Mon Sep 08, 2003 9:42 pm
It seems like a lot of people have seat trouble and even after taking back to the dealer many people still have the same problem.
Obviously Toyota can't listen to everyone's complaints about small annoyances and immediately post a recall or fix it notice. I'm sure there are guidelines somewhere in the company that categorize recalls.
I would think loose seats would jeopardize people's safety. I'm surprised they overlooked this annoyance. They were aware of this in 1999. But it seems like they repeated the error for the 2000s.
solara_man2000
Postby TadS » Tue Sep 09, 2003 7:54 am
Ok, this is what I did. I stuffed some balled up cloth into the wire support stuff under the seat. It's alot better now. The problem seems to be with the lower cushion from what I can tell.
TadS
Re: Ignore problems
Postby Jai_Jai_Binks » Tue Sep 09, 2003 8:36 am
HEHE...I work as a valet parked in the weekends...After driving all those SUV's, trucks and other cars....I'm happy to go back to my solara..Dav is right...i think the engines and the wind noice is SOO less that all those inside pin drops are amplified....Honda is the only other manufacturer that I've seen that makes great solid cars. Nissan does produce great cars...but their lower segment (altimas' and sentra) make up all the bad rep for making crappy cars.....
