SolaraGuy.com • View topic - door lock
door lock
door lock
Postby AzN_DrAgoN48 » Sat May 17, 2003 9:57 pm
my passenger side door lock can't lock even though its in the locked position. i can't turn it to the unlocked position either. anyone have any ideas?
2001 Dark Blue Solara SE V6
8000k Osram HID
Silverstars fogs
Clear Corners
Passport 8500 Hardwired
Two Alpine 12" Type R Subs
JBL BP600.1
AzN_DrAgoN48
Re: door lock
Postby krook » Sun May 18, 2003 1:30 am
AzN_DrAgoN48 wrote:my passenger side door lock can't lock even though its in the locked position. i can't turn it to the unlocked position either. anyone have any ideas?
your motor might be frozen in the lock position. whadya mean it can't lock even though it's in the lock position? like you can't even close the door?
krook
Postby AzN_DrAgoN48 » Sun May 18, 2003 7:38 am
no like i can open the door, when the lock is in the locked position. i can't move the lock back to the unlocked position either. but my door still opens
8000k Osram HID
Silverstars fogs
Clear Corners
JBL BP600.1
AzN_DrAgoN48
Postby Jackass-Jeff » Sun May 18, 2003 10:08 am
Sucks for you =x you keep running into problems...
I don't know if would apply to Solaras, but in my old car, that happened. It was a mechanical linkage failure inside the door... it was a recall issue, but yea... maybe you can open up the door and check? I'm not sure what you'd check for since we have power locks... but it's worth a shot if it may just be something like a small pebble in the way
1GR-FE ftw!
Jackass-Jeff
Postby Yanks0114 » Sun May 18, 2003 10:57 am
Best bet is to take off the door panel and see whats going on in there
Postby AzN_DrAgoN48 » Sun May 18, 2003 7:03 pm
should i remove the door and check whats going on? or jsut take it to the dealer? how do i remove the paneling anyway?
8000k Osram HID
Silverstars fogs
Clear Corners
JBL BP600.1
AzN_DrAgoN48
Postby Jackass-Jeff » Sun May 18, 2003 8:35 pm
THere are a few screws on the door...
if your car is still under warranty, move your ass to the dealer :D
1GR-FE ftw!
Jackass-Jeff
