SolaraGuy.com • View topic - Second 12V power outlet problems
Postby TXSolaraSLE » Mon May 19, 2003 2:11 pm
My extra 12V power outlet (the one below the ashtray) in my 99 SLE isn't working. How do i get behind the dash to test the wiring? I already checked all the fuses so its gotta be something else. Any suggestions?
Thanks,
Brian
TXSolaraSLE
Postby Yanks0114 » Mon May 19, 2003 3:27 pm
http://carstereohelp.com/stereoremovalToySolara.htm
Take the dash apart and make sure all the connections are tight.
Postby Luc » Mon May 19, 2003 6:59 pm
Taking the dash apart has nothing to do with the 12V high-current accessory output. To get to the that output, you will need to pry up the shifter panel, as that is a complete one piece, and pull away from the dash. Check the plug and/or contacts.
1998 S/C'd 1MZ-FE A/T
Luc
Postby Gunman » Mon May 19, 2003 8:06 pm
check the fuses under the hood as well? Just wondering.
Gunman
Postby Missay » Mon May 19, 2003 9:25 pm
You do have the car on or the key at least turned to get power...right??? :drinking:
hahah..just checking.
Melissa
Missay
SolaraGuy Ambassador
