SolaraGuy.com • View topic - Help!!! Check Engine Light 2002 Solara
Postby NKS » Tue May 20, 2003 1:27 pm
I recently bought a used 2002 Solara SE Four Cylinder coupe. It had about 28000 miles when I purchased it. I just surpassed the 30K mark when I noticed this morning the check engine light came on stayed on. Any ideas at what this could mean? Has anyone else experienced this issue?
NKS
Postby Stock Solara SEV6 » Tue May 20, 2003 2:58 pm
Could be a hundred different things. It's still under warranty so you can take it to the dealer to read the code(s). The only time mine came on is when the gas cap wasn't on tight enough. If you don't get the cap on tight -- until it starts clicking -- the check engine light will come on.
If you think this is the case, tighten the gas cap and then disconnect the battery for 15 minutes or so to reset the light. If that was the problem, the light won't come back on. If it wasn't the problem, see the dealer or purchase a code scanner.
Stock Solara SEV6
Postby krook » Wed May 21, 2003 1:34 pm
it's still under warranty. take it back to the dealer. might be your O2 sensor.
krook
Postby FLASH » Wed May 21, 2003 7:00 pm
There's probably something wrong with your engine. Check your engine. LOL :rofl:
Bring it to the Dealer.
==FLASH==
(Sister's) 2011 "Pink Prius"
FLASH
Postby Cyanide41 » Thu May 22, 2003 10:05 am
Stock Solara SEV6 wrote:Could be a hundred different things. It's still under warranty so you can take it to the dealer to read the code(s). The only time mine came on is when the gas cap wasn't on tight enough. If you don't get the cap on tight -- until it starts clicking -- the check engine light will come on.
I had that same thing happen to me. I was worried it was something serious, because the day before I thought I might of found an oil leak. Then I chirped the tires coming out of a drive way and the light went on. Turned out it was just the gas cap. I felt pretty stupid
JAMES
SC3 Member
To find out how you can own this solara, send an e-mail slvrstreamsolara@aol.com
Cyanide41
Postby Flipside909 » Thu May 22, 2003 11:06 am
Have your CEL code read by the dealer.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
