SolaraGuy.com • View topic - Full Transmission Flush
Postby impactX » Thu Jun 05, 2003 6:09 pm
Do you guys go back to Toyota to do it? It doesn't seem that expensive up here in Vancouver Canada.
Also I think I should get a B&M tranny cooler soon. I want the tranny to last a bit longer :)
impactX
Postby AzN_DrAgoN48 » Thu Jun 05, 2003 7:44 pm
when should you do the full flush?
2001 Dark Blue Solara SE V6
8000k Osram HID
Silverstars fogs
Clear Corners
Passport 8500 Hardwired
Two Alpine 12" Type R Subs
JBL BP600.1
AzN_DrAgoN48
Postby impactX » Thu Jun 05, 2003 10:47 pm
35k Mile?
I should do it at 50k km... I am in Canada
But I want to do it sooner, I drive it hard.
impactX
Postby DavPak » Fri Jun 06, 2003 4:10 am
~45K is recommended.
'02 Solara S/C'ed V6 5-spd
DavPak
Postby Guest » Fri Jun 06, 2003 8:50 am
Don't forget to change the air in your tires every 3000 or else your Toyota will fall apart. Better still get a Honda !:lol:
Guest
Postby Mole » Fri Jun 06, 2003 10:17 am
Anonymous wrote:Don't forget to change the air in your tires every 3000 or else your Toyota will fall apart. Better still get a Honda !:lol:
Mr. Guest- show your name and brain... you must be smoking your rice too hard... this is a TOYOTA forum, so why would you go and promote a different car, let alone Honduh?
who the hell changes their AIR in the tires every 3k?
why the hell did you post about air in the tires when the orginal thread is about transmission flushing.
Now back on topic. if the dealer does the flush for a decent price, then go for it. down here in Ca, i head to a local shop, b/c he does not charge tax and labor. check other local shops to get a good understanding of how much it should go for. Toyota usually charges preeeemo price.
Postby SC V6 » Fri Jun 06, 2003 10:32 am
word.... also.. where do u get a tranny cooler? because I want to get one also.. please pm me or soemthing.. let me know!
thanks
Scott
SC V6
Postby TadS » Fri Jun 06, 2003 12:13 pm
I got mine from Summit. They had that best price I could find on one. Pretty quick shipper too, at least for me they were :).
TadS
Postby SC V6 » Fri Jun 06, 2003 6:25 pm
how hard to install?
SC V6
Postby NASTY » Fri Jun 06, 2003 10:04 pm
(TRDMole177, that was a joke from a thread a while ago - not that it makes the post any more ON topic)
'01 SLE V6
NASTY
Postby impactX » Fri Jun 06, 2003 10:18 pm
About the AT cooler, I think it's not that hard to install, just have to make sure everything hooks up properly and install the cooler in front of the radiator. Usually around 1 hour of work.
impactX
Postby SC V6 » Sat Jun 07, 2003 8:07 am
is it in the way at all??? like.. is it low to the ground??... is it in the way at all?
SC V6
Postby TadS » Sat Jun 07, 2003 12:26 pm
I had mine installed by a shop for $80. Basically, the bottom right corner of the transmission cooler is lined up with the bottom right corner of the radiator. It's black so unless I point it out to someone it's pretty much invisible. The shop used some plastic to cover the lines and protect them from rocks. Overall I think it looks great. I’ll go take a picture and send it to you.
TadS
Postby indiglosolara » Sat Jun 07, 2003 1:35 pm
Hey can you send me some pic of that also
Sent to: Kennyha1981@yahoo.com
Thanks
Kenny
indiglosolara
Solara 2 xB
Solara 2 xB
Postby impactX » Sat Jun 07, 2003 7:25 pm
Can you send a picture to birkeythelion@hotmail.com please?
Thanks!
impactX
