SolaraGuy.com • View topic - Dash Sensor
Dash Sensor
Dash Sensor
Postby Skew » Mon Jan 19, 2009 7:15 pm
I was following a pm to disable my DRL's I needed to unplug the grey plug and unhook the sensor on the dash... My question is:
Does the sensor housing come out or do I cut the wires? I tried to pull it out but i wasn't successful. So is it ok to cut the wires?
Skew
Postby LEE337 » Mon Jan 19, 2009 11:20 pm
I was wondering the same thing. Ive been searching on here for an answer, but no luck. I disconnected the grey plug too so I wouldnt f*ck up my HIDs. Then when I got to the sensor on the dash, I didnt find anyway to disconnect it. :think: I didnt want to start hackin away at the wires, so I just left it alone. So Im in the same boat as you.
Postby TxBmbleBee » Tue Jan 20, 2009 12:12 am
the sensor on the upper right part of the dash does disconnect...believe me i would know :)
TxBmbleBee
Postby LEE337 » Tue Jan 20, 2009 6:31 am
TxBmbleBee wrote:the sensor on the upper right part of the dash does disconnect...believe me i would know :)
Hmm, I guess my wires must be hung up or something. How far do we to pull out the sensor to reach the disconnection plug???
Postby TxBmbleBee » Tue Jan 20, 2009 9:33 am
not sure, i dont believe it was too far tho
TxBmbleBee
Postby r0w » Tue Jan 20, 2009 10:06 am
you wont be able to pull it up very far so just pull it up as much as u can without putting to much stress on the wires. reach in and disconnect that bad boy and you are good to go. :D Trust me its there, when i did mine i think i used a screw driver to help me push in that pin to release the plug from the socket. hope it this helps. GL
r0w
Postby Skew » Tue Jan 20, 2009 10:17 am
Thanks much gentlemen.
Skew
