SolaraGuy.com • View topic - "E-Brake light" problem
Postby impactX » Thu Jul 03, 2003 10:10 pm
Brakepads are wearing out and low on brake fluid.
Top it up with dot3/dot4 brake fluid and check how much % of the pad is left.
impactX
Postby Guest » Thu Jul 03, 2003 10:14 pm
SEARCH
Guest
Postby NASTY » Fri Jul 04, 2003 5:39 am
Anonymous wrote:SEARCH
...yeah, thatll probably fix the problem!
'01 SLE V6
NASTY
Postby chef solara » Mon Jul 07, 2003 5:16 am
I had the same problem, all you need to do is top off your brake fluid. and it will go away.
chef solara
Postby DavPak » Mon Jul 07, 2003 6:31 am
chef solara wrote:I had the same problem, all you need to do is top off your brake fluid. and it will go away.
for now.......but the question remains, why is your brake fluid low?
aha, maybe its front pads you need.
'02 Solara S/C'ed V6 5-spd
DavPak
