SolaraGuy.com • View topic - does your interior fog up easily?
Postby Guest » Wed Jul 09, 2003 1:41 am
i find that when i get inside my solara it fogs up VERY easily.
does anyone have this same problem?
Guest
Postby Yanks0114 » Wed Jul 09, 2003 5:06 am
I've noticed that too. Try some rainx anti fog, it works excellent
Postby Jackass-Jeff » Wed Jul 09, 2003 6:31 am
yea... it's common on solaras and gen 4 camrys
1GR-FE ftw!
Jackass-Jeff
Postby Jai_Jai_Binks » Wed Jul 09, 2003 6:56 am
When i was in wisconsin, i bought fog-sponge...its a basic sponge with some fibers by the end..to absorbe condensation...essentially..once in two months..i just wipe it with that...and i'm pretty much fog free! Do you guys play with the vents...to get the fog off...rather than using a/c...try heat!
Postby Jackass-Jeff » Wed Jul 09, 2003 7:42 am
jhbhatia wrote:try heat!
It always clears up just the same... except that I'm sure most would prefer the A/C over heat hehehe... I just turn it on the highest setting for like 5 seconds, and the fog is completely gone.
1GR-FE ftw!
Jackass-Jeff
Postby hari-bhari » Wed Jul 09, 2003 8:35 am
does anyone notice that if you turn the controls to the winshield defogger, the a/c (compresor) turns itself on automatically, regardless of whether you have the a/c button activated or not. i guess it has to be this way, since the only way you can remove the fog is with dry air, and the compressor removes the moisture.
hari-bhari
Postby FLASH » Wed Jul 09, 2003 10:02 am
I've noticed that it really only fogs up when im in the backseat with my girlfriend, or on cold mornings
==FLASH==
(Sister's) 2011 "Pink Prius"
FLASH
Postby Phenom24 » Wed Jul 09, 2003 7:08 pm
I tell you what, our Avalon is the worst with fog/condensation. My wife and I took my brother and his wife up to a Devils game in January - and with us 4 talking in the car the windows fogged up and wouldn't clear.
That's the ONE thing I really dislike about the Avalon...
(it's a 96, granted, but SO annoying)
Glenn
Now that I know you I could never turn my back away
Now that I see you I believe no matter what they say
Phenom24
Postby tiredolddog » Wed Jul 09, 2003 7:18 pm
hari_trivedi wrote:does anyone notice that if you turn the controls to the winshield defogger, the a/c (compresor) turns itself on automatically, regardless of whether you have the a/c button activated or not. i guess it has to be this way, since the only way you can remove the fog is with dry air, and the compressor removes the moisture.
It's not a bug.... It's a feature :drinking:
tiredolddog
Postby Hsakuragi » Wed Jul 09, 2003 9:19 pm
The best way os "open ur window, open AC and use COLD air" it's faster than using heat
Hsakuragi
Postby ronin » Wed Jul 09, 2003 9:30 pm
if you guys have an air freshener, that could be it. rain-x does work very well to clear it up.
ronin
Postby hari-bhari » Thu Jul 10, 2003 8:28 am
tiredolddog wrote:It's not a bug.... It's a feature :drinking:
of course. if the compressor wasnt on, blowing the moist air on your windshield may even make it worse instead of helpin. toyota was clever for including this feautre, becuase most people think its just the air blowing that defogs your window, but its really needs to be cold, dry air
hari-bhari
Re: does your interior fog up easily?
Postby Guest » Fri Jul 11, 2003 2:30 am
Anonymous wrote:i find that when i get inside my solara it fogs up VERY easily.
uh huh...and what are you doin in your car?? :-? Remember...it curses your car.... :o
Guest
Postby SolarYellow » Sat Jul 12, 2003 5:22 pm
Why hasn't anyone mentioned that if the ventilation system is set on recirculate the interior will fog up? Make sure the little arrow is coming from the outside, not the inside.
SolarYellow
Postby hari-bhari » Sun Jul 13, 2003 11:46 am
SolarYellow wrote:Why hasn't anyone mentioned that if the ventilation system is set on recirculate the interior will fog up? Make sure the little arrow is coming from the outside, not the inside.
not necessarily. the thing that causes fog is when the air inside the car is warmer and more humid than the air outside of the car. it helps some if you have fresh air coming from outside, but then you are just making your a/c compressor work harder
hari-bhari
