SolaraGuy.com • View topic - pcv valve
pcv valve
pcv valve
Postby hari-bhari » Fri Jul 11, 2003 3:41 pm
hey guys, ran a search, couldnt find any instructions on replacing the PCV valve, if anyone can write a lil step by step on replacing this part, i would really appreciate it. thanks
hari-bhari
Postby Poman » Fri Jul 11, 2003 3:47 pm
Looking at the Hayne's manual, it says it's in the valve cover. But it doesn't really show you in the picture of where it is and what it looks like. I'm looking forward to replace mine by kinda confused with the manual as well!
Poman
Postby 99solarai4 » Fri Jul 11, 2003 8:06 pm
Replacing the PCV valve is one of the easiest things you can do. Just pull it out of the grommet on the valve cover, use pliers to move back the clamp on the hose that goes to the other end of it, remove the hose and there you go. Reverse to install. If you are still having trouble finding the PCV valve, just listen for the thing that is clicking on top of the valve cover (unless yours is all sludged up). Good luck. :D
'99 Solara SE i-4
Back to Stock
99solarai4
Postby hari-bhari » Sat Jul 12, 2003 6:24 am
hey, thanks for the instructions, but i have NO clue where this valve cover thing is. sorry, a pic might help if u dont mind. thanks
hari-bhari
Postby Poman » Sat Jul 12, 2003 7:58 am
For the 4 cylinder model I think it's easy to replace becuz it looks like it's on top of the valve cover. For V6 is different.
Poman
Postby hari-bhari » Tue Dec 16, 2003 10:49 pm
99solarai4 wrote:Replacing the PCV valve is one of the easiest things you can do. Just pull it out of the grommet on the valve cover, use pliers to move back the clamp on the hose that goes to the other end of it, remove the hose and there you go. Reverse to install. If you are still having trouble finding the PCV valve, just listen for the thing that is clicking on top of the valve cover (unless yours is all sludged up). Good luck. :D
i kno its been a long time, but i still havent done this. does anyone have a picture of this valve cover so i can get it done? thanks!
hari-bhari
Postby WTF?? » Wed Dec 17, 2003 9:23 am
hari_trivedi wrote:i kno its been a long time, but i still havent done this. does anyone have a picture of this valve cover so i can get it done? thanks!
You got a PM Hari
Retired... its been fun Image
WTF??
Postby SC V6 » Wed Dec 17, 2003 10:14 am
whats this mod do anyway?
later
Scott
SC V6
Postby kubi » Wed Dec 17, 2003 11:08 am
Not really a mod, more maintenence. Kind of an emissions thing. Sends air coming out that still has gas in it back to the intake manifold.
Please stop humping my car, owner privilege!
kubi
