SolaraGuy.com • View topic - Water pump leaking / Replace @ 30.5k!
Postby shidosha01 » Thu Jul 17, 2003 5:33 pm
Pretty bummed about it but I was getting my radiator flushed at 30k and my mechanic told me I had a water pump leak. Good thing my car still falls under the 60months/60,000 mile warranty. Just picked up my car today at Ourisman Fairfax Toyota and they replaced everything. :)
Has anyone else here had problems with their water pump before 60k?
Ourisman Toyota told me that this is the first they had a 1MZ-FE with 30k that had to get the water pump replaced.
Rizal D. / Forever "tabasco"
99 V6 SE 5spd FT61 1MZ-FTE
393whp/445ft-lbs. TQ @15psi
shidosha01
Postby Jai_Jai_Binks » Fri Jul 18, 2003 1:25 am
i"ve never heard of such...i've had an uncle who had a problem with his camry (1mz) by that was towards 130K mark...your tooo young in milage to have that happen! How does your car run (prior to install of new w/pump)...was the temp. constant..any weird noises...
Postby Fletch » Fri Jul 18, 2003 3:13 am
I had my water pump replaced at 99k when I had the timing belt done. It was showing a little wear, but would have been good for many more miles.
2006 Legacy GT spec.B
Fletch
Postby crash2 » Fri Jul 18, 2003 9:40 am
Fletch wrote:I had my water pump replaced at 99k when I had the timing belt done. It was showing a little wear, but would have been good for many more miles.
got mine done at 108K. I can hear the water pump grinding at the morning start. Timing belt and accessory belts too. The accessory belts had little cracks on them already.
30k is a little pre-mature. how's your driving style/commute?
crash2
Postby shidosha01 » Fri Jul 18, 2003 11:03 am
I didn't experience any weird noises coming from the engine....only from the supercharger :wink: ....but as far as my driving habits...I rarely even gun it or even race. 15% to 10% racing.
shidosha01
