SolaraGuy.com • View topic - question about replacing a rear bearing
Postby beanslicer » Thu Jan 21, 2010 12:47 pm
hey guys, so my rear bearing is squeaking and making a humming noise at higer speeds, so i ordered a new one to replace it, since its a whole assembly i figured it shouldnt be too crazy to replace, but the local mechanic quoted me with 1.5 hours labor, normally that wouldnt be a big deal, but i am a poor college student, and since i am pretty handy, i think i can change it myself.
anyway, i just just wondering if anyone has ever done it before and knows how to, or maybe can even post a tutorial.
this is with the ABS
http://www.partsgeek.com/gbproducts/BN/ ... oogle+Base
second one on that page (rear right)
any help would be greatly appreciated
beanslicer
Postby ~SolaRaSpeed~ » Thu Jan 21, 2010 2:37 pm
I would suggest you have a new o-ring if the one you ordered didn't come with one.
~SolaRaSpeed~
Postby 99BlackSandv6 » Thu Jan 21, 2010 4:13 pm
I'm in the same situation man. The same corner too. Good Luck :up:
Postby cj145 » Thu Jan 21, 2010 4:38 pm
It is very simple to replace that whole piece...
Take the wheel off
Take the caliper off
Take the rotor off
Reach in with a 14mm socket on a 6" extension to the back 4 bolts. You might have to push the e-brake parts out of the way using the socket to get it over the bolts.
Assembly is the same in reserve. Hub bolts get torqued to 59ft/lbs. Remember to replace the oring that is against the backing plate with a new one.
cj145
Postby ASG14 » Thu Jan 21, 2010 5:45 pm
ASG14
Postby ASG14 » Thu Jan 21, 2010 5:46 pm
ASG14
Postby 99BlackSandv6 » Thu Jan 21, 2010 7:13 pm
^NICE!!!
Postby beanslicer » Thu Jan 21, 2010 11:14 pm
~SolaRaSpeed~ wrote:I would suggest you have a new o-ring if the one you ordered didn't come with one.
where do i get a new o-ring, can that be gotten at the local auto-parts store, and is it cheap?
99BlackSandv6 , hell i wish you lived closer man, i woulda driven over to at least work on this project with someone else. :) good luck to you too.
and to all you guys, thanks so much, you are really helpful and knowledgeable!
beanslicer
Postby cj145 » Fri Jan 22, 2010 7:03 am
You can get them at a dealership. A pair of them (one for each side) shouldn't be more than $8-10 even marked up.
cj145
Postby ASG14 » Fri Jan 22, 2010 7:21 am
^ You should know, lol. BTW, I need to find out the thread for the line and I'll let you know.
ASG14
Postby beanslicer » Sun Jan 24, 2010 10:40 pm
new bearing should arrive tomorrow, hopefully ill replace it sometime this week, do you know if its dangerous to drive far with a bad bearing?
beanslicer
Postby ASG14 » Mon Jan 25, 2010 8:07 am
^ If it;s at the end, it "could" sieze up.
ASG14
Postby 99BlackSandv6 » Mon Jan 25, 2010 1:08 pm
Hey beanslicer,
What company did you go with for the bearing? Where did you buy it?
I think I'm going with the Timken unit from Autozone. Good luck to you too.
Postby beanslicer » Mon Jan 25, 2010 9:03 pm
i went with the one here: http://www.partsgeek.com/catalog/2000/t ... embly.html
the one for 75 bucks, its only takin them 3 buisness days to deliver which i think is good, and my mechanic said that even a cheaper bearing should last me 50k miles, so i figured there is no real reason to opt out for the one thats $150 more.
i just *bought* a torque wrench from sears and my friend should be avail to help me out by thurs, so hopefully ill do this thing before i drive to PA 150 miles each way for a snowboarding day haha.
btw, my name is lex (and i just posted a picture in the post a picture discussion), whats your guys names?
beanslicer
Postby 99BlackSandv6 » Mon Jan 25, 2010 9:09 pm
Lex,
I'm Ben, I think you're probably right about the price difference. I hope the stuff you get works as long as you need it to. I think I'll go with Timken just to be safe, I plan on having the car for a really long time. I posted a picture of me in the pic thread too. I'm under the Green Giant. :D
