SolaraGuy.com • View topic - QUESTION???
QUESTION???
QUESTION???
Postby Jai_Jai_Binks » Tue Aug 05, 2003 7:58 am
Am going to be doing a 30K service on my solara (i know i can't believe, shes' already 30...i still remember the day i got her home from the dealership..new car smell and all...anyhow back to the topic).....
I talked to two toyota tech's...and they both said differently. I think I agree with one of them.....it is recommended that I replace the ATF fluid, and the differential fluid. Both of them, have their own drain plugs.......However, one of the tech's claimed that they drain the differential fluids and fill them with ATF for the auto 5sfe's. Had it been a M/T then they fill it with differential fluid. I think to agree with him...but i wanted to get your all's opinion before i do ahead and do this service done....Any thoughts (wish flip was still here to show me the light)...
PS: I need to know this before friday, so that i can buy the right stuff for this weekend....also should 4 quarts be enough for this....??? (ie. 4 bottles).
Postby Fletch » Tue Aug 05, 2003 9:05 am
I would get the auto trans fluid changed whenever it's recommended. Auto trans fluid level and condition is very important.
The manual trans fluid is synthetic. I checked it's condition at 100,000 miles and it looks as good as new. It has never been changed and I don't plan on changing it until/unless the clutch needs to be replaced.
2006 Legacy GT spec.B
Fletch
Postby happy_aggies » Tue Aug 05, 2003 9:53 am
I thought Tranny fluid is every 60k?
It does not hurt tho...
I just changed my ATF to Royal Purple and it's awesome. 8)
happy_aggies
Postby impactX » Tue Aug 05, 2003 10:56 am
Change it whenever it's starting to have a burnt smell.
5S-FE's differential is a dead end unit. You will need to drain AND use a suction pump to pump in new fluid from the side of the differential.
For the tranny, if you need to do the whole tranny flush instead of just dropping the pan + changing the ones out of the differential, 4 quarts are far from enough.
I don't have the Haynes manual with me so I can't remember the exact numbers.
impactX
Postby Jai_Jai_Binks » Tue Aug 05, 2003 12:19 pm
thanks for you help...so the 4 quarts should be good for both right (ATF filling and differential filling)? - most likely i'll just give it to a friend or a local shop to do that for me (with me buying the parts) - darn..the older you get one gets NO TIME! and also, arief...i got the thing to change atf from alldata.com is it supposed to be changed at 60K????....cus' then i could wait for another 30K miles.... :angel: pls advise friends....
Postby happy_aggies » Tue Aug 05, 2003 1:16 pm
Just look at ur scheduled maintenance interval.
I lost mine so... could not really tell. DavPak may be able to say sumtin.
happy_aggies
Postby impactX » Tue Aug 05, 2003 4:26 pm
jhbhatia wrote:thanks for you help...so the 4 quarts should be good for both right (ATF filling and differential filling)? - most likely i'll just give it to a friend or a local shop to do that for me (with me buying the parts) - darn..the older you get one gets NO TIME! and also, arief...i got the thing to change atf from alldata.com is it supposed to be changed at 60K????....cus' then i could wait for another 30K miles.... :angel: pls advise friends....
Do you happen to have your owner's manual? I believe it says how many quarts you need in both differential and the tranny. (not including flush of course)
I suggest you ask a friend to do it. Even if you buy the ATF yourself (synthetic?), you can never find out if they have put that into your car until it's too late - that is when your ATF starts burning in a year or 2, you'd know the shop didn't put in the synthetic ATF you brought.
impactX
