SolaraGuy.com • View topic - What fluids are you currently using?
Postby lexmex » Fri Mar 05, 2010 7:44 am
I've been curious because I'm being a guinea pig with my RX300 (it's also got a 1MZFE like the V6 Solara), but I wanted to see what everyone was using with regard to the specific fluids mentioned below, so that I might try out others in the future:
Engine Oil:
Oil Filter:
Transmission Fluid:
Power Steering Fluid:
Brake Fluid:
My current ones are:
Engine Oil: Castrol Syntec 0W30 (last time I was regularly using something different was many, many years ago with Mobil 1 0W40)
Oil Filter: K&N HP-2009 (that's larger than the OEM sized HP-1002)
Transmission Fluid: Redline D4 (was using Amsoil ATF)
Power Steering Fluid: Mobil 1 ATF (was using Valvoline Synthetic PSF many, many years ago)
Brake Fluid: Pentosin DOT4 (was using ATE SuperBlue)
lexmex
Re: What fluids are you currently using?
Postby Dawgz » Fri Mar 05, 2010 7:54 am
lexmex wrote:I've been curious because I'm being a guinea pig with my RX300 (it's also got a 1MZFE like the V6 Solara), but I wanted to see what everyone was using with regard to the specific fluids mentioned below, so that I might try out others in the future:
Engine Oil: Mobil 5000 5w30
Oil filter: Pure One Purolator PL10241
Transmission Fluid: Mobile 1 Synthetic ATF Mercon V
Filter: OEM Toyota spec
Power Steering Fluid: Mobile 1 Synthetic ATF Mercon V
Brake Fluid: Prestone Synthetic
Postby jetbtkng » Fri Mar 05, 2010 9:20 am
eng oil mobil 1 20-50
Transmission Fluid man, royal purple
filter's fram.................. :drinking:
Postby 99BlackSandv6 » Fri Mar 05, 2010 10:18 am
Engine Oil: Mobil 1 Extended Life 5w-30
Oil Filter: Mobil 1
Transmission Fluid: Valvoline Dexron/Mercon
Power Steering Fluid: Toyota
Brake Fluid: Toyota
Postby Bippusol » Fri Mar 05, 2010 10:20 am
Engine Oil: ENEOS 5W-30
Oil Filter: Toyota OEM filter
Transmission Fluid: not enough miles to change yet.. lol
Power Steering Fluid: I think Prestone
Brake Fluid: Prestone...
lol autozone ftmfw
01 SE-V6, Stock as Fock (=
Bippusol
Postby SoLarry » Fri Mar 05, 2010 10:56 am
Engine Oil: Whatever they use at the Jiffy Lube
Oil Filter: ditto
Transmission Fluid: Whatever came with it from the factory
Power Steering Fluid: ditto
Brake Fluid: ditto
1991 Oldsmobile Toronado
2004 Toyota Solara SE
SoLarry
Postby SoSleek » Fri Mar 05, 2010 12:59 pm
SoLarry wrote:Engine Oil: Whatever they use at the Jiffy Lube
Oil Filter: ditto
Brake Fluid: ditto
n00b! LOL :D
SoSleek
Postby Mole » Sat Mar 06, 2010 12:47 am
gatorade...
for the cars, dino oil.
Postby SoSleek » Sat Mar 06, 2010 1:35 pm
WAAAAAAATER SUCKS.....GATORADE is better!
SoSleek
Postby TadS » Sun Mar 07, 2010 4:19 am
Engine Oil: Valvoline High Mileage 5w-30
Oil Filter: Whatever is on sale
Power Steering Fluid: O.E.
Brake Fluid: Castrol Dot 5
The truck is getting Mobile 1 0w-20. At least it's on a 5k interval.
TadS
Postby x99suplarax » Sun Mar 07, 2010 4:38 am
Engine Oil: royal purple 10w-30
Oil Filter: k&n 2009
Power Steering Fluid: toyota
Brake Fluid: toyota
x99suplarax
Postby youngblood » Mon Mar 08, 2010 12:09 pm
Engine Oil- Valvoline Full Synthetic 5w30
Oil Filter - Toyota
Trans Fluid and Filter - Stock, never replaced
PS and Brake - Stock, Never Replaced (by me)
Black 2004 Solara SLE V6
Green 2002 Camry LE I4
youngblood
Postby SleeperSolara » Tue Mar 09, 2010 10:00 am
Engine Oil: Castrol Full Syntheic 5W-30 for winter, 10W-30 for summer.
Oil Filter: Bosch 3330
Transmission Fluid: Royal Purple ATF
Power Steering Fluid: Not sure, whateva's in the car......
Brake Fluid: OEM Toyota brake fluid.
