SolaraGuy.com • View topic - no power to OEM cd player.
Postby wekillyou » Sat Mar 06, 2010 10:06 pm
I recently changed my dome light (that has been out for three years) and now my factory radio won't turn on (doesn't even light up). I checked the fuse on the inside panel (behind coin door) and it appears fine. any other ideas as to what it might be?
wekillyou
Postby corlon » Sat Mar 06, 2010 11:23 pm
does the dome light work, or is it out. the radio memory wire might be under the hood. i think its the same as the dome light power fuse.
NiCe
corlon
Postby wekillyou » Mon Mar 08, 2010 9:47 am
the dome light now works, and I replaced the fuse for the radio and nothing... this is killing me. and what do you mean radio memory wire?
wekillyou
Postby corlon » Mon Mar 08, 2010 10:51 pm
i thinks there is two different power sources for the radio. 1 is the 12volt memory power. the other is the 12volt acc power. do you know what the fuse is labelled as that your checking is good?
NiCe
corlon
Postby Inverted » Tue Mar 09, 2010 6:51 am
check the fuse under the hood.
Inverted
Postby corlon » Tue Mar 09, 2010 6:58 pm
under hood fuse should be labelled radio 1 and is a 20 amp fuse.
inside fuse box is radio 2 fuse for acc which should be a 7.5 amp fuse.
NiCe
corlon
Postby wekillyou » Wed Mar 10, 2010 10:23 am
where is the fuse under the hood?
wekillyou
Postby corlon » Wed Mar 10, 2010 11:10 am
in the fuse box next to the battery near the left fender.
NiCe
corlon
Postby wekillyou » Wed Mar 10, 2010 11:59 am
just tried it... NOTHING.
this is killing me.
wekillyou
Postby corlon » Wed Mar 10, 2010 8:01 pm
i guess the next step is to pull the radio and check to see if you have power on both those wires. if you do i'm guessing your radio is shot.
NiCe
corlon
Postby wekillyou » Thu Mar 11, 2010 1:35 am
how do I get the unit out?
wekillyou
Postby mazen222 » Fri Mar 12, 2010 5:53 am
before you do anything, check the radio memory dome light wire, its under the hood, or the dash.
if you want to remove the unit take off the ashtray, the cig lighter and pull the dash trim from there and work your way up, it has clips. unplug the cig lighter wire once you take the bottom section off.
PS. ignor first drunk comment.
1999, 5 Speed V6
mazen222
Postby wekillyou » Mon Mar 15, 2010 2:44 am
mazen222 wrote:before you do anything, check the radio memory dome light wire, its under the hood, or the dash.
what and where is the memory wire?
wekillyou
Postby mazen222 » Mon Mar 15, 2010 10:02 am
nevermind that man... it was a joke, but reading it now i realize its no funny lol
1999, 5 Speed V6
mazen222
Postby wekillyou » Tue Mar 16, 2010 3:58 pm
So i just noticed that my day time lights are no longer coming on... what the hell happened when I changed my dome light!?
wekillyou
