SolaraGuy.com • View topic - What are ways to blow your knock sensors?
Postby impactX » Thu Aug 07, 2003 6:30 pm
as titled
impactX
Postby Yanks0114 » Thu Aug 07, 2003 8:25 pm
run very lean with forced induction.
You probally wont have trouble on a stock car, but with F/I thats where you can have trouble
Postby impactX » Thu Aug 07, 2003 9:33 pm
Thanks!
(Don't worry, I am not trying to blow it. Just wanna know how to prevent it) :)
impactX
Postby Mole » Thu Aug 07, 2003 9:56 pm
you can prevent by using higher output injectors, or get a air fuel convertor
Postby WTF?? » Fri Aug 08, 2003 7:08 am
Where the heck is the knock sensor and how would you know its blown?
Retired... its been fun Image
WTF??
Postby cdssolara » Fri Aug 08, 2003 8:50 am
solara nytez wrote:Where the heck is the knock sensor and how would you know its blown?
The knock sensors are located under the intake manifold, and there is one each for the front and rear banks of cylinders on a V6. You would first know that there is a problem if you get a check engine light, and a scan will let you know if it's related to the knock sensors. Sometimes, the CE light is just giving you a warning, in which case the light will go off after a couple of days. If one of the sensors is blown, the light will stay on.
I had a lot of problems with my #2 knock sensor when I went to 5.5 psi of boost. Since getting new cylinder heads, I'm now running 7 psi of boost with no problems.
cdssolara
Postby Fletch » Fri Aug 08, 2003 10:00 am
---cdssolara---
Is the #2 knock sensor on the front or rear bank?
2006 Legacy GT spec.B
Fletch
Postby SC V6 » Fri Aug 08, 2003 10:55 am
rear
SC V6
Postby cdssolara » Fri Aug 08, 2003 11:20 am
Like Scott said, it's the one for the rear bank.
cdssolara
Postby 808Camry » Sat Aug 09, 2003 2:33 am
So would a 5.5 psi run okay with an SAFC?
808Camry
Postby Yanks0114 » Sat Aug 09, 2003 7:49 am
808Camry wrote:So would a 5.5 psi run okay with an SAFC?
A 5.5PSI pulley should be no problem even without a SAFC if you have 93 octane, but it is highly reccomended that you do get the SAFC and have it dyno tuned.
