SolaraGuy.com • View topic - shaved emblems leaving a mark
Postby kronos98 » Sat Aug 09, 2003 9:34 pm
I shaved the emblems off the back of my car, but since my car is a '99, the emblems were on there for quite some time. As a result, there are marks on the body where they used to be. With a little effort, you can see the shapes of each emblem in the finish.
I've tried waxing and polishing it a few times, but the marks aren't going away. It's been a few months since I've done it, and it's not going away on its own. Do you guys know what I can do about it?
kronos98
Postby bassthrive » Sat Aug 09, 2003 9:52 pm
Clay bar it. Same thing happened to me when I removed "toyota" from the trunk. You could still see the word on the car after I took it off. I used WD-40 to clean the residual glue and prep it. Then rubbed it clean with a clay bar, maybe a little meguairs paint cleaner, and finally waxed it.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby Fletch » Sun Aug 10, 2003 4:34 am
You could "very carefully" use some rubbing compound. Not advised if the car is a dark color though, it will leave witness marks.
2006 Legacy GT spec.B
Fletch
Postby kronos98 » Sun Aug 10, 2003 11:39 am
clay bar? where do you get it? like elementary school clay?? i've heard the term here and there...do i get it at an auto store?
kronos98
Postby Yanks0114 » Sun Aug 10, 2003 1:19 pm
kronos98 wrote:clay bar? where do you get it? like elementary school clay?? i've heard the term here and there...do i get it at an auto store?
A clay bar can be found at an auto store. Its not like the clay from elementary school but i removes almost everything, bugs, tar, some surface scratches.
Do not use rubbing compound, use polishing compound if you must
Postby kronos98 » Sun Aug 10, 2003 9:05 pm
sweet! thanks so much guys!
kronos98
