SolaraGuy.com • View topic - White Pasty Buildup on Battery
Postby krzyray » Sun Aug 17, 2003 9:27 am
I checked my battery and there was a lot of white pasty buildup on the top center of it (where the bolt is holding it down). Anybody know what this is? I have 32k and this is the stock battery. Is this stuff normal? I cleaned it off.
krzyray
Postby onefiend » Sun Aug 17, 2003 9:59 am
I am having the same problems, I'm pretty sure its battery acid. Ive been wanting a new battery for awhile, I dont know whether I should wait till this battery dies or not. That white pasty stuff is actaully battery acid along with the melted paint of that black bar that holds the battery down. If your sistaution is the same as mine, I think I know what your saying.
Just make sure you keep the battery terminals (wires) clean and if it starts to get worse then buy a new battery.
onefiend
Postby Mole » Sun Aug 17, 2003 11:16 am
mix backing soda with water, pour it over the build up. it should eliminate the build up, follow with a tooth brush to scrub off access gunk.
repeat if neccessary
ps. depending on how old the battery is, change it. i change mine every 3 years, regardless on how many months is advertised.
Postby Jai_Jai_Binks » Mon Aug 18, 2003 2:23 pm
They make a tool (don't know what its called or if its even got a name), its specifically designed to clean the battery terminals! I'd for 2 bucks at local shops (autozone, pepboys). If you go in and ask, they'll try and sell you a kit - its like wet towels, the tool and marking rings - the tool is like a steelwool for the terminals, the cloth is like a wetsipe, and the rings..are like RED FOR POSITIVE and you got the rest...I think the kit is for 4-6 bucks (not worth it). just buy the tool seperatly!
Postby happy_aggies » Mon Aug 18, 2003 4:20 pm
Dont forget to get the pad that prevent acid build up.
Those are pretty effective. comes in pair around $2-3. (green/black n red)
happy_aggies
Postby krook » Mon Aug 18, 2003 7:55 pm
there's also a spray that you can use. just go to any auto parts store or even any walmart should have it. it's a battery acid cleaner and it also prevents acid from returning. it sprays yellow liquid, but turns red/pink if it touches acid.
krook
Postby pecora55 » Mon Aug 18, 2003 10:46 pm
ive heard of putting a penny and pouring water on it will work, i did it myself and it worked....
Goodbye solara, loved you while i had you :( now into my bros hands, and hello Spec V...BYE BYE SpecV HELLO 04 Maxima ;)
'04 Maxima SE
'03 Sentra SpecV(SOLD)
'99 Solara SLE V6 Auto(SOLD)
pecora55
Postby Yanks0114 » Tue Aug 19, 2003 3:14 pm
pecora55 wrote:ive heard of putting a penny and pouring water on it will work, i did it myself and it worked....
Yes and no. Because the copper is easier to oxidize the acid will attack that instead, the water just makes the reaction possible. Its a hydrolysis reaction.
The problem is you didn't neutralize the acid so watch your hands on the penny. Use baking soda, its the best method
Postby pecora55 » Tue Aug 19, 2003 3:25 pm
yes i know the water makes it happen lol....and after i did that it didnt come back until the battery finally died and had to get a new one...either way...it all works....
'04 Maxima SE
pecora55
