SolaraGuy.com • View topic - Coolant: Red or Green?
Postby krzyray » Sun Aug 17, 2003 12:04 pm
How come everyone says to use Red coolant, and not Green coolant? I have 32k right now, and I changed my coolant at 30k. I know that it came with red, but I put green in. Will my car be ok?
krzyray
Postby krawzyazn » Sun Aug 17, 2003 1:10 pm
toyota's must use red some kinda differant formula in the chemicals once should be ok don't do it repeadly
Postby onefiend » Sun Aug 17, 2003 2:25 pm
why'd you use green? is it cheaper? 1 gallon of the red coolant is $14 at the Toyota dealership. I bought it 2 weeks ago and I flushed my radiator myself. The sales person at the parts/service department says red is better to use for our Toyotas, he didnt go into detail about it. I know green is the most commonly used, why is that? Anyone know the difference between the two?
Did you mix the green along with the red? Or did you flush out the red and then put in the green?
onefiend
Postby krawzyazn » Sun Aug 17, 2003 3:56 pm
green you can get for like 3-8 dollars
Postby Yanks0114 » Sun Aug 17, 2003 4:25 pm
green needs to be changed very often. Red is good for atleast 100k miles
Postby ICUFG » Sun Aug 17, 2003 4:32 pm
Red coolant has no Silicone in it, green has silicone in it and it will slowly start to eat the insides of our cooling systems. I highly recommend using the Red, especially if you want your warranty to pay for some thing that went wrong with the cooling system.
ICUFG
Postby krzyray » Sun Aug 17, 2003 5:10 pm
onefiend wrote:why'd you use green? is it cheaper? 1 gallon of the red coolant is $14 at the Toyota dealership. I bought it 2 weeks ago and I flushed my radiator myself. The sales person at the parts/service department says red is better to use for our Toyotas, he didnt go into detail about it. I know green is the most commonly used, why is that? Anyone know the difference between the two?
I flushed out the red, and then put the green coolant in. I found that people also prefer the red coolant at lexus forums: http://us.lexusownersclub.com/forums/in ... =7&t=1177&
They said that mixing green and red is a bad idea because it will create sludge. So hopefully I did a good flush :roll: I guess I'll just have to see what happens with the green.
Is it necessary to fill the overflow tank with coolant?
krzyray
Postby Yanks0114 » Sun Aug 17, 2003 5:13 pm
I hate to say it but you're pretty dumb for using green coolant. Also NEVER EVER mix coolant. Do not overfill either, there is a line that you should not exceed.
These are the times i miss flipside
Postby xXsolaraXx » Sun Aug 17, 2003 5:31 pm
Yanks0114 wrote:I hate to say it but you're pretty dumb for using green coolant. Also NEVER EVER mix coolant. Do not overfill either, there is a line that you should not exceed.
wow! a very stern point well noted...but calling him dumb? tsk tsk! :wink:
xXsolaraXx
Postby Yanks0114 » Sun Aug 17, 2003 10:18 pm
Its true. There is no reason to use the green stuff. Any toyota dealer will tell you to use red. Also the owners manual makes a point of it. If our cars were designed to run on the red, why would you put in the green.
Its also part of the n00b hazing :wink:
Postby DavPak » Mon Aug 18, 2003 3:24 am
TOYOTA/LEXUS ONLY USE RED
'02 Solara S/C'ed V6 5-spd
DavPak
Postby WTF?? » Mon Aug 18, 2003 7:48 am
When I went to my dealership, the customer service guy told me the toyota red coolant doesnt corrode like the green coolant. Like yanks said even if you do switch the green, ensure that you completely flush out the red, then put in the green (I wouldnt recommend since toyota uses it).
even if the green is a couple bucks cheaper, in the long run, using the red, you wont have to worry about your coolant as much as the green
just my 2 cents
Retired... its been fun Image
WTF??
Postby Jai_Jai_Binks » Mon Aug 18, 2003 7:56 am
Whats with the noobie hazing?? :agrue:
Red coolant at the dealership is for 9 bucks and some loose change (i think for the month of august)..I just bought three (since i have 3 cars to flush). Its savings of some loose change. generally, you don't have to flush that often...keeps your car running like its supposed to....keeps radiator corotion down! When i flush, i mix 60-40 for the water/coolant. If it needs more mix in the radiator a few weeks down the road...then i use straight water in the rediotor...and straight coolant in the resivor! (yeah, you got to flush the resivor as well, cus' then your mixin' the red and green!)
Postby krawzyazn » Mon Aug 18, 2003 8:52 am
i paid full price out the door was freaking $17
Postby Mole » Mon Aug 18, 2003 10:10 am
scarff up a little for small cleansing, instead of bending over and the dealer behind you when your radiator corrodes.
