SolaraGuy.com • View topic - Steering Fluid
Steering Fluid
Steering Fluid
Postby Hsakuragi » Sun Aug 31, 2003 6:09 pm
I'm boring so I'm reading the solara manual, on the Steering section, it said
POWER STEETING FLUID TYPE:
Automatic transmission fluid Dexron II or III...
Is that a mistake or wat?
I'm using Valvoline Synethinc Blend Power steering, is it ok or what?
Also, for the transmission, I know the v6 use 5.0qt of fluids, does this include the oil in the torque converter?
I'm trying to use a pump to pump all the fluids out, it's easier than get under the car and drain the fluids out. I did on oil change with the pumps, and it did sucked out almost 5 qts of oil (there are marked level on the bottle..) 8)
Hsakuragi
Postby Mole » Mon Sep 01, 2003 7:22 am
you used a pump for the motor oil? i think it's just easier to do it the old fashioned way. anywho... about the tranny fluid. since your tapping into the torque convertor area, why dont you make sure you put in as much as much as you took out?
if you were to service the tranny by unplugging the plug at the tranny pan, i think only 3 qrts comes out.
Re: Steering Fluid
Postby Flipside909 » Tue Sep 02, 2003 6:22 pm
I'm using
Not at all. That's the correct fluid for Toyota Power Steering Units.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby Hsakuragi » Tue Sep 02, 2003 6:37 pm
But how come the power steering fluid on the bottle doesn't seem looks like red color?
Will other Power steering fluid ok to use?
Thanks Flip.
Hsakuragi
Postby happy_aggies » Tue Sep 02, 2003 6:38 pm
Hmm... perhaps I can change it to Royal Purple? 8)
happy_aggies
Postby Guest » Wed Sep 17, 2003 5:24 am
I have a 2000slev6 Solara, and the power steering fluid that it came with from the factory was NOT auto trans fluid. I recently flushed the system using Valvoline synthetic power steering fluid.
Guest
Postby Hsakuragi » Wed Sep 17, 2003 8:39 am
That's wat i'm using now, does anyone here know WHY the recommendation is ATF as power steering fluid?
Hsakuragi
Postby Guest » Thu Sep 18, 2003 5:33 am
I would NOT suggest you use a pump to change your oil. You will not get all the junk in the bottom of the oil pan. Get you oil hot and remove the oil drain plug to drain, remove filler cap while draining.
The automatic transmission pan holds 5 quarts, but I think the total capacity is around 12 quarts. I recently flushed the transmission fluid by disconnecting the return line from the OEM cooler incorporated in the radiator and connecting a clear line and inserting into a graduated waste bucket. Get fluid hot first before disconnecting and while car is running, add fluid to transmission at the same rate as it is going into the waste bucket. Use a clear line and when it is running a nice red you are done.
I found that the transmission had a flow rate of 1 quart every 20 seconds.
Guest
Postby noodlerooney » Sun Dec 26, 2004 3:46 pm
I have been told that Toyota uses a non red dyed Dexron III fluid for their power steering fluid.
I would recommend the use of a Dexron III fluid, mineral or synthetic.
15,001 miles, Garage Queen
noodlerooney
Postby bassthrive » Sun Dec 26, 2004 4:16 pm
Anyone want to post a tutorial for changing power steering fluid?
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
