SolaraGuy.com • View topic - Weird engine sound
Weird engine sound
Weird engine sound
Postby HKSV6SLE » Mon Sep 01, 2003 3:51 pm
after i got my headunit and 4 channel amp put in..my car started to make this weird sound...sounds..like slight whirring sound...similar to the sound a turbo makes when spooling up..but not as loud...i was thinking interference...but im not sure..anyone know where it could be coming from? it actually sounds kinda cool..but i wanna make it sure its not damaging anything..........
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby Yanks0114 » Mon Sep 01, 2003 4:57 pm
is the sound coming through the speakers?
Sound like it is interference. Check your grounds. Run the RCA on a different side than the power, and use high quality wire
Postby SC V6 » Mon Sep 01, 2003 6:13 pm
its the RCA's running too close to the exhaust... my brothers car was doing that.. and it was the RCA's picking up the exhaust noise
SC V6
Postby HKSV6SLE » Mon Sep 01, 2003 8:43 pm
its not coming out of the speakers...i turned my radio completely off..and it still makes that noise..the noise disappears under hard throttle tho.....weird....
www.lexusnet.com
HKSV6SLE
Postby Mole » Mon Sep 01, 2003 10:21 pm
upgrade your rca cables.
Postby Turbosolara » Tue Sep 02, 2003 1:43 am
Maybe the firewall rubber wasnt place properly, so you can hear that sound from engine. If not, open you hood and exam which part does it come from
Postby Yanks0114 » Tue Sep 02, 2003 8:35 am
See if the noise still happens when the power isn't connected. Pull the fuse on the power wire and check for noise
