SolaraGuy.com • View topic - How to take out the grill?
Postby Solaradude » Wed Sep 17, 2003 5:29 pm
Ok There are 3 nuts...and i could loosen the top part but then I cant get the bottom part out. Can someone help me out here?
THanks in advance.....
Steve
Solaradude
Postby FLASH » Wed Sep 17, 2003 7:23 pm
Supposedly, you have to use a little force and take it off the clips attached to the bumper at the bottom of the grille, however I couldn't do that because I thought it would break. I just did the work on the grille with it on the car....speaking of which, why do you need to remove it?
==FLASH==
(Sister's) 2011 "Pink Prius"
FLASH
Postby Solaradude » Wed Sep 17, 2003 8:03 pm
im making my OWN custom grill.....im gonna have to take the grill off of my car because im gonna cut the lil lines.....sand down the chrome part what not.....and it's gonna look tight if i could get it off lol :evilbat:
Solaradude
Postby FLASH » Wed Sep 17, 2003 8:46 pm
As another custom grille person, I'm excited to see how it'll turn out! Other options you may have are going to a junkyard and taking a grille from there incase you mess up. Just figgured I'd throw that out there if you want to explore your options.
==FLASH==
FLASH
Postby Fletch » Thu Sep 18, 2003 3:55 am
It's easier to work on it with it out. There are at least 3 clips at the bottom. I pryed them out with a flat head screwdriver. Take a look at it and you'll see clips at each end of the grille and one in the middle.
I took the Toyota emblem off the front, bondo'ed the holes, sanded the plastic chrome off and sprayed it semi gloss black. I think it looks pretty good and it was a cheap mod.
2006 Legacy GT spec.B
Fletch
Postby STR8PYP » Thu Sep 18, 2003 6:36 am
Pull hard. :)
SC
STR8PYP
Postby Solaradude » Fri Sep 19, 2003 11:54 am
Ok, I already took out the grill :) :) :) and I just finished sanding the chrome part down....now I have to bondo those small holes or.....im going to cut the vertical lines.
I will keep you guys posted..... :evilbat:
I will bankroll your poker career!! visit www.instant-bankroll.com
Solaradude
