SolaraGuy.com • View topic - Just a ???
Just a ???
Just a ???
Postby hnda8r » Thu Sep 18, 2003 4:03 pm
I was just curious if you can mix lowering springs?? :roll: I want my front end to look like my back end. I bought the eibach pro-springs, but the front and is still pretty high. I want both my front and back end to be flush, but I dont want to spend money to buy a whole new entire spring set. :o
In search for my next Supercharged Solara!!!
hnda8r
Postby indiglosolara » Thu Sep 18, 2003 4:40 pm
I would not recommend it cus diff springs have diff settings. if you would like a clean look all the way around i would buy the tein's then sell your eibachs. its a better value that way. but i have the teins in my car and i love the drop.. i have a 1 finger gap all the way around.
Kenny
indiglosolara
Solara 2 xB
Solara 2 xB
Postby krawzyazn » Thu Sep 18, 2003 6:28 pm
you can do it
won't harm the car at all
we used to do it all the time with hondas lol
neuspeed with eibach
Postby HKSV6SLE » Thu Sep 18, 2003 7:26 pm
the srping rate is gonna be all different..but then againm..ppl used to cut their springs....so....but then again aren't the teins different drop in front and back..?
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby indiglosolara » Thu Sep 18, 2003 7:55 pm
Yea.. the teins are 1.6F and 1.4R, while the eibachs are 1.6 all around..
Kenny
indiglosolara
Solara 2 xB
Solara 2 xB
Postby xXsolaraXx » Thu Sep 18, 2003 8:17 pm
actually thats not true...the eibachs are NOT 1.6 around...they are 1.2 all around...however you can request what i got which is 1.6 and 1.2...
moe
xXsolaraXx
Postby DavPak » Fri Sep 19, 2003 11:56 am
um, did anyone bother to open up the box their springs came in?
the front and rear are DIFFERENT! the rears are larger (top to bottom) than the front.
the only way to get a different drop in front than in back, hnda8r, is to put one brand (i.e. Tein) in the front and another (i.e. Eibach) in the rear.
'02 Solara S/C'ed V6 5-spd
DavPak
Postby hnda8r » Mon Sep 22, 2003 4:28 am
Thanks for the info GUYS!!! :D
hnda8r
Re: Just a ???
Postby Kocho » Mon Sep 22, 2003 6:16 am
hnda8r wrote:I was just curious if you can mix lowering springs?? :roll: I want my front end to look like my back end. I bought the eibach pro-springs, but the front and is still pretty high. I want both my front and back end to be flush, but I dont want to spend money to buy a whole new entire spring set. :o
The gap in the front being bigger does not necessarily mean the car is dropped less. Measure the distance under the car (where you jack-up) to see if it is an even drop. I'm pretty sure you'll find out the front is actually a fraction of an inch lower than the back measured this way. The front wheels need more space than the rear in turns to avoid rubbing.
If it is for looks and the way you like it more - then OK, you can lower the front further. But I personally wouldn't like my car looking like a Neon - with the ass-up, only to get rid of the fender gap in the fornt...
Kocho
Postby hnda8r » Mon Sep 22, 2003 7:28 am
Thanks Kocho, Ill measure the distance today.
I dont think the back end will stick up hgher than the front, but there is only 1 way to find out :roll: I appreciate your help BTW
hnda8r
