SolaraGuy.com • View topic - ? about Rim/Tire sizes
Postby B_Master_Flash » Sat Oct 04, 2003 11:44 am
I am thinking about getting new rims after I lower my car, and I wanted to know people's opinions about sizes. What size wheel/tire combo are people here running and what would you guys recomend? I want to go with tires as thick as possible, and I was wondering if I could get 245/40s to fit and what size wheel would it have to go on. I'm thinking 18x7.5" wheels, any info/comments people have would be appreciated.
B_Master_Flash
Postby FLASH » Sat Oct 04, 2003 12:25 pm
My rubber is 215/50/17, I didn't want to worry about popping tires or bending rims, and I'll have plenty of clearance once I lower it, so i'm very pleased with my decision.
==FLASH==
(Sister's) 2011 "Pink Prius"
FLASH
Postby impactX » Sat Oct 04, 2003 4:56 pm
245 is too wide
You need 225/40/18. I am not sure about 235/40/18 either.
impactX
Postby HKSV6SLE » Sat Oct 04, 2003 6:26 pm
you could do 245....but then again..it'll probably stick out and that looks funny..but you could do it...but then agin..you might hit your fenderwell on turns....so...
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby swimshady906 » Sun Oct 05, 2003 5:32 pm
Depends on the off set of your wheels, their size, what appeals to you as far as wheel-stick-out-ness and how much fender you want to roll. Good Luck. Im lowered with the TIEN/tokico combo with 225/40/18 on +42 and it looks like i could fit 235 pretty easily....
02' S2000 Silverstone
swimshady906
What size to get?
Postby robsatx » Wed Oct 15, 2003 4:51 pm
I would like to put 17" wheels on my 99 v6sle. I am looking at some 17X8 Momos what size tire should I use? Is 17X 8 to wide?
Thax
robsatx
Postby Mole » Wed Oct 15, 2003 9:09 pm
having an 8' rim, you would need at least a p225 tire size.
i myself have 18x8.5 running on 225's but i plan to get 235's on the next set.
with the correct offset and within reason rim width, the wheel/tire should not look out of the oridinary.
Thanks, wheel question.
Postby robsatx1 » Thu Oct 16, 2003 9:32 am
The wheel size is
17x8 Et 35 5x114.3
What size tire do I need for this and will it work with my 99 Solara, V6 SLE,
robsatx1
Re: Thanks, wheel question.
Postby Mole » Thu Oct 16, 2003 9:37 am
robsatx1 wrote:The wheel size is
17x8 Et 35 5x114.3
you will need at least p225, 45, 17. with that offset, you should be fine, however is there anything higher? like 38 or 40?
offset
Postby robsatx1 » Fri Oct 17, 2003 4:59 am
No more offset, this is a wheel that I can get.
Also, someone told me the rear would rub. Do you guys think the car will look strange?
Btw, I tried to create a user name and I never received an email. Can you guys point me in the right direction?
robsatx1
car newbie needs help with rims
Postby msangapu » Wed Dec 10, 2003 10:42 am
i have a 99 solara
i'd like to get 18" rims for it
i've been lookin around and i think 18"/8.5" rims should fit fine, right?
and tires... 225/40/18 is that okay?
basically i want to be able to get the wheels and put them on myself w/o any fender modifications or anything else.
also, i know the car will be jacked up.. any suggestions on lowering the car? how much will i need to lower it with 18"s on there ??
thanks
msangapu
Re: car newbie needs help with rims
Postby WTF?? » Wed Dec 10, 2003 11:25 am
msangapu wrote:i've been lookin around and i think 18"/8.5" rims should fit fine, right? and tires... 225/40/18 is that okay?
As TRDMole says above... you should be fine
lowering your ride... thats a different topic, but you can do any combo, just hit up the Search function at the top and you should find LOTS of info :D
Retired... its been fun Image
WTF??
Postby impactX » Thu Dec 11, 2003 3:43 am
8.5" will need a different front and rear offset and you will not longer be able to rotate your tire.
Lowering or not, strut clearance is the same.
impactX
Postby Grazi07 » Thu Dec 11, 2003 7:22 am
wow, I'm surprised this thread made it so far without more search function suggestions..... way to be Nytez...this info should be added to the FAQ imo
Team Nex-Gen: The new breed of speed!
Check us out at www.teamnexgen.net
Grazi07
SolaraGuy UConn Guy
SolaraGuy UConn Guy
Postby SolaraT » Thu Dec 11, 2003 4:25 pm
Grazi07 wrote:wow, I'm surprised this thread made it so far without more search function suggestions..... way to be Nytez...this info should be added to the FAQ imo
LOL! I agree. :lol:
SolaraT
Solaraguy need mo power guy
