SolaraGuy.com • View topic - How to change shifter on an A/T with overdrive
Postby envyedsolara » Wed Oct 08, 2003 7:04 pm
HOW DO I CHANGE THE SHIFTER ON AN AUTOMATIC WITH OVERDRIVE TO AN AFTERMARKET SHIFTER WIT O/D BUTTON.
envyedsolara
Postby FLASH » Wed Oct 08, 2003 7:45 pm
1) lose the caps lock 2) That is not a tutorial.
But my guess would be to unscrew the screws on the shifter, and see waht you can do from there. did you find an aftermarket shifter with an O/D button? Ive been looking...
==FLASH==
(Sister's) 2011 "Pink Prius"
FLASH
Postby Yanks0114 » Wed Oct 08, 2003 8:10 pm
Thanks flash.
Envyed you have to start following the rules.
Postby HKSV6SLE » Wed Oct 08, 2003 9:03 pm
i think levoc makes one...or napolex...
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby Hsakuragi » Wed Oct 08, 2003 9:37 pm
razo, i had one ..obx copied it with a cheaper price i think.. took me few hours to install it with my friend...
Hsakuragi
Postby Jai_Jai_Binks » Thu Oct 09, 2003 6:52 am
a few guys on celica.net (5th genners and 6th genners) placed a button where the shifter is (for the od - kinda like a power/economy button on the lexus's). Hence, for those looking for aftermarket shifters...you don't have to restrict yourself to ones with an inbuilt button!
Postby HKSV6SLE » Thu Oct 09, 2003 11:11 am
i know they make the aftermarket shifter with the o/d button..i think nissan's have a button like that on their shifters also....try searching some more....
www.lexusnet.com
HKSV6SLE
Postby Hsakuragi » Thu Oct 09, 2003 12:36 pm
installation, you need to take out the OEM shift, cut the OD power (need real careful doing this if you don't want to take everything apart to get in the whole consel), rewire the od power line with the new shift, install shift, and da da you are done.
Hsakuragi
Postby Hsakuragi » Thu Oct 09, 2003 12:38 pm
one more thing, once the OEM shift is cut and replaced, it's hard to put it back on...unless you really need to part out the transmission shifter and put extra wires to make it long enough.
Hsakuragi
Postby krook » Thu Oct 09, 2003 3:17 pm
hsakuragi wrote:installation, you need to take out the OEM shift, cut the OD power (need real careful doing this if you don't want to take everything apart to get in the whole consel), rewire the od power line with the new shift, install shift, and da da you are done.
that's what i was thinking.
ENVY DID YA GET THAT?!?
krook
Postby SpikedMantis » Thu Oct 09, 2003 10:11 pm
HKSV6SLE wrote:i think levoc makes one...or napolex...
I believe they are the same company.
SpikedMantis
Postby Hsakuragi » Thu Oct 09, 2003 10:49 pm
imotorgear.com is the place you need, it's expensive to change for auto....(avg 80-110 ...stupid OD)
I was thinking the same thing too, if you really know how to DIY, you can get a shift W/O the OD, all you need is just an extra button/switch and customize to it somewhere near your shifter because the most important part is dealing with the OD wire, other parts is easy. I bet you can save at least 30 bucks.
You can check my razo shift pic at the picture section.
Hsakuragi
Postby Guest » Fri Oct 10, 2003 4:38 am
would it be possible to use the trd shift knob also? Do you know if anyone has done this, if so please post pictures. Thanks 8)
Guest
Postby Hsakuragi » Fri Oct 10, 2003 8:03 am
don't think so, since it's not a knob, you need to change the WHOLE shift for the auto
Hsakuragi
