SolaraGuy.com • View topic - Anyone Seen 1MZ-FE Fail?
Postby 700t » Thu Oct 09, 2003 1:39 am
Has anyone seen or heard of 1MZ-FE(3.0 V6) fail(blow up) and if so what component broke.
I'm curious to know how tough this engine is.
700t
Postby Jackass-Jeff » Thu Oct 09, 2003 1:47 am
Turbo Mag or someone did a 1MZ tear-down and said that it can handle a lot of boost but you need upgraded pistons. THe pistons in there are weak.
The only thing I've heard being blown in the engine are the knock sensors when they are supercharged
1GR-FE ftw!
Jackass-Jeff
Postby Fletch » Thu Oct 09, 2003 3:38 am
1mz-fe's are renound for lasting 300k miles or more. Boost and hard driving will probably take a little life off the engine but I have no idea how much. I'm guessing the first internal that would need to be replaced would be piston rings, which can be done in chassis.
2006 Legacy GT spec.B
Fletch
Postby DavPak » Thu Oct 09, 2003 8:58 am
i've seen several 1mz-fe's in sienna's where the soccer mom neglected her oil changes and the engine either sludged up or seized. that's about it though, and i see a lot of them!
'02 Solara S/C'ed V6 5-spd
DavPak
Postby HKSV6SLE » Thu Oct 09, 2003 12:47 pm
that i've never seen.....and remember..this engine is in a lot of toyota cars...sienna, camry, i think the rx 300 too....
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby Hsakuragi » Thu Oct 09, 2003 12:49 pm
the engine has at least 10 year history.. i think
Hsakuragi
Postby hari-bhari » Sat Oct 11, 2003 10:08 am
engine in my 95 avalon was a 1mz-fe and it blew due to sludge i beleive. had to pay for new engine :cry:
hari-bhari
Postby indiglosolara » Sat Oct 11, 2003 10:30 am
hari_trivedi wrote:engine in my 95 avalon was a 1mz-fe and it blew due to sludge i beleive. had to pay for new engine :cry:
How did ou engine develop sludge?? Was it due to Improper oil changes..?? the main question is what was the cause of the sludge?
Kenny
indiglosolara
Solara 2 xB
Solara 2 xB
Postby krawzyazn » Sat Oct 11, 2003 12:14 pm
i seen a 1mz blow after a guy boosted 9 pounds from his sc
Postby Guest » Sat Oct 11, 2003 1:15 pm
my parents skimped on oil changes i beleive, but not too much, they waiting about 4500-5000 miles. but in the manual it says every 3000-5000 miles anyways, so it should have been fine. but all 1mz-fe engines from 97-02 or something are covered for sludge damage. sadly, ours wasnt, even tho it was the same damn engine :roll:
Guest
Postby hari-bhari » Sat Oct 11, 2003 1:40 pm
^ me
hari-bhari
Postby B_Master_Flash » Wed Oct 15, 2003 11:07 am
Kenny
I know that using cheap oil (like penzoil) and not changing it often enough leaves deposits and can cause sludge.
B_Master_Flash
Users browsing this forum: Google [Bot] and 15 guests
