SolaraGuy.com • View topic - Solara Remote Keyless Entry
Postby bfl62581 » Mon Oct 20, 2003 9:55 am
All,
I have an 00 SE Solara (V6 5-speed). I have the nice pretty blinking red light on my gauges to tell me I have key security. My question is, many cars nowadays are built with alarms in them regardless, but in order to use the alarm, you have to purchase this option from the dealer, in which they pull out a FOB, program it to your car, and hand it to you.
Are the Solara's the same way? ie, can I get a FOB off of eBay, and have it work to remote lock/unlock? I have a car alarm, but it tends to act up, and if this is the case, then there's a whole lot more I can build directly into the car's factory wiring.
bfl62581
Postby Jackass-Jeff » Mon Oct 20, 2003 11:11 am
Yea you can!
Check your current one... on the back it'll have a serial code... that is the model that you need for your car. It's the "FCC ID"
Then you have to find instructions on how to program it... each model differs =\ Some are ridiculous sounding (press gas 5x, brake 2x, open close door, etc etc) lol but it works =x
1GR-FE ftw!
Jackass-Jeff
Postby Grazi07 » Mon Oct 20, 2003 11:32 am
Is there any other place on the car to find the FOB ID?
Team Nex-Gen: The new breed of speed!
Check us out at www.teamnexgen.net
Grazi07
SolaraGuy UConn Guy
SolaraGuy UConn Guy
Postby HKSV6SLE » Mon Oct 20, 2003 1:06 pm
i dunno is it in the owners manual? but yea check the factory Id
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby Jackass-Jeff » Mon Oct 20, 2003 7:44 pm
Ask someone else that has the same year fob and if they have the factory alarm
1GR-FE ftw!
Jackass-Jeff
Postby bfl62581 » Tue Oct 21, 2003 9:09 am
I have a 2000 SEV6 5-speed. Can someone check to see their FCC ID for me? I have never had the remote, as I did not purchase that "option", as I was going to get an aftermarket alarm, but now my aftermarket alarm is being a whore, but I miss the lock/unlock ability.
bfl62581
Where's the code?
Postby Lobo74 » Wed Oct 22, 2003 6:22 am
Where can you find the information on how to code your remote to get the security to work?
Lobo74
Postby Jai_Jai_Binks » Wed Oct 22, 2003 7:18 am
i have a 2001 SE (i got two remotes from the dealer) and acquired another two from ebay (they were off a 2000 Sev6)....all remotes were programmed..so the one i'm having today is
FCC ID - G043VT14T
CAN - 1470 102 849
(don't remember if this is the one i bought off ebay or the one the dealer gave me...??) Hope this helps.
Postby Guest » Tue Nov 04, 2003 1:29 am
Try www.keylessride.com
I bought two fobs for $122 w/programming instructions.
The intructions are pretty funny....push in key, pul out key, open and close door three times etc.
Guest
Postby Jai_Jai_Binks » Tue Nov 04, 2003 7:32 am
Anonymous wrote:Try www.keylessride.com
Ebay would be WAY cheaper. I got mine two for under 20 shipped! (xerox copy of the instructions were included)
Postby mienmariani » Wed Dec 03, 2003 9:22 pm
Hey, does anyone know if the keyfobs with the trunk-opening option will work for the 2000 se solaras? I want to get one from ebay but don't know if there is a solenoid in the car or whatever is needed for it to work. Thanks much!
mienmariani
Postby HKSV6SLE » Wed Dec 03, 2003 9:54 pm
it won't work..i already looked into it, the only way would be to have the thing ( not sure what's it called) that pops the trunk open, i wanted to get it added to my Clifford alarm, i think you can add a solenoid tho to do the same thing.
www.lexusnet.com
HKSV6SLE
Postby the_pack_rat » Wed Dec 03, 2003 9:54 pm
I was wondering the same as mienmariani.
Also -
I've been researching & it appears the Toyota alarm kit for a 2000 Solara without factory keyless entry(RS3000), is pretty much just "plug & play", with no splicing into any wiring.
Is this indeed true ?.
TIA,
Eric
2000 SE V6
the_pack_rat
Postby HKSV6SLE » Wed Dec 03, 2003 9:59 pm
get an aftermarket one..much better than the factory one any of the factory ones..i recommend the Matrix Rs3 which is what i have,...
www.lexusnet.com
HKSV6SLE
Postby the_pack_rat » Wed Dec 03, 2003 10:05 pm
I still like the fact the factory one is "plug & play" without splicing into stuff.
Call me stubborn.
Guess I better put the flame suit on now.
lol
Eric
the_pack_rat
