SolaraGuy.com • View topic - FIBERGLASS BODYKIT
FIBERGLASS BODYKIT
Postby HKSV6SLE » Mon Nov 10, 2003 9:09 pm
eh if you could you should save the money up and get a urethane kit fiberglass tends to crack easily and if you hit anything kiss it goodbye
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby geminimouse » Mon Nov 10, 2003 9:16 pm
Only the trd lip kit is in urethane
If your looking for something more extreme there's VIS and Black Widow which is fiberglass.
Here's the bw:
08 Accord Coupe
99 Solara Sold on 7/7/07
geminimouse
Postby Guest » Tue Nov 11, 2003 7:57 am
i like the black widow kit- how much does it cost to install and paint? This place in boston charged 1000 for paint and labor. Is that a good price?
Guest
Postby kubi » Tue Nov 11, 2003 8:20 am
The black widow kit will cost more to install because the sides and rear don't fit correctly. Those pieces will have to be shaped to fit which is timely and therefore costly.
kubi
Postby Guest » Tue Nov 11, 2003 9:20 am
what other bodykits are there for solara beside TRD, molly, and blackwidow
Guest
Postby FLASH » Tue Nov 11, 2003 9:50 am
Anonymous wrote:what other bodykits are there for solara beside TRD, molly, and blackwidow
TRD IS Molly...there's also the R34...and the heh heh Ondergroud Design One...Yuck!
==FLASH==
(Sister's) 2011 "Pink Prius"
FLASH
Postby TadS » Tue Nov 11, 2003 6:36 pm
That's a dangerous question, cheap up front might equal expensive to install / maintain as the fitment might be crappy, or the fiberglass shoddy. The best prices I have seen on kits have been on eBay, but then again that's only the initial cost.
TadS
Postby kubi » Tue Nov 11, 2003 6:48 pm
The TRD kit would seem more expensive because of the cost of the kit, however when you take into account that there is no other kit that fits perfectly, you save quite a bit on the installation, plus they are made out of urethane instead of fiberglass. I have TRD side skirts and rear valances with a Black Widow front bumper, however the entire TRD kit would have been about the same amount with all said and done.
As far as the durability of fiberglass, I have a Black Widow front bumper that has gone through many scrapes driving on the worthless roads in Missouri... So I try to stay in Kansas :) It has held up for about 3/4 of a year now with no damage. Impacts to a fiberglass bumper will not be as forgiving as a normal bumper, however, even at low speeds. I've never had problems with pot holes, it's the steep inclines that make me cringe hearing the bumper rub.
kubi
Postby SpikedMantis » Tue Nov 11, 2003 6:56 pm
Don't forget about paints jobs - the fiberglass kits come unpainted where the TRD/Molly comes matched to your car's color.
SpikedMantis
Postby geminimouse » Tue Nov 11, 2003 6:58 pm
kubi wrote:It has held up for about 3/4 of a year now with no damage. Impacts to a fiberglass bumper will not be as forgiving as a normal bumper, however, even at low speeds. I've never had problems with pot holes, it's the steep inclines that make me cringe hearing the bumper rub.
I hear that scraping sound everytime I go down my driveway...but I stuck on aluminum sheets under the bumper to protect it.
08 Accord Coupe
geminimouse
Postby MGLax13 » Tue Nov 11, 2003 8:21 pm
You can also install the TRD kit yourself (from what I hear) but the other kits, you'd have to take to a body shop and let them do it.
MGLax13
SolaraGuy Solara13
SolaraGuy Solara13
Postby Astro » Tue Nov 11, 2003 11:48 pm
kubi wrote:The black widow kit will cost more to install because the sides and rear don't fit correctly. Those pieces will have to be shaped to fit which is timely and therefore costly.
Ain't that the truth. I'm already looking at about $3000 for install, custom molding, and paint (whole car). I paid $600 for the kit. If I didn't have it all molded who knows how much it would cost! Remember, what you don't pay for in the kit, you will PAY for in the installation!
