Oil in combustion chamber
I was changing my spark plugs yesterday, and I was very upset to find oil in the combustion chamber of cylinder #4 (3rd in firing order). What do you guys think valves, rings, or pistons? If it were any of these things what would you recommend getting done at the same time? For example, if it's a bad valve guide should I just go ahead and replace the head with one built by Flatlander? If it's the rings or pistons with they have to pull the motor? This is a little out of my scope of knowledge, and it's going to put a damper on my planned supercharger purchase
, but I figure if I am already going to have parts out of the motor I may as well get better than O.E. upgrades, as the labor is going to be the most expensive part of whatever is wrong. Thx for your thoughts. BTW, I am over 100k now.
TadS - SolaraGuy Supporter
. If I wouldn't have been changing the plugs I wouldn't have even known there was a problem. Anyway. I have a diagnostic scheduled for Tuesday. When I find out exactly what's wrong I'll post up a "Whose parts should I Buy?" list.
